Before the invention of long-lasting, high-output LED light bulbs and high-capacity rechargeable batteries, flashlights generally did not provide a significant light source and were basically intended to provide enough light to see in front of yourself for common uses like camping or a power outage.
But now, these new type of flashlights recommended for everyday carry (EDC) are called tactical flashlights and what makes these flashlights different from their predecessors are their smaller size, rugged waterproof aluminum construction, substantial brightness, and a high-capacity rechargeable battery.
>>Why not own these flashlights
>>Olight Warrior X Turbo Black 1100Lumens Hunting Torch
✔ Powerful For Its Size
Warrior X Turbo delivers a max output of 1,100 lumens, a max throw of 1,000 meters.
✔ Long Runtime
Powered by a 5000mAh 21700 battery, it enjoys a max runtime of 12.5 hours.
✔ Simple and Aggressive Design
Asserting its tactical identity,the Warrior X Turbo is an ideal lighting tool for hunting, search and rescue, law enforcement and outdoor activities.
✔ Magnetic Remote Pressure Switch
The magnetic tail switch also serves as the connection port for the magnetic charging cable and the magnetic remote pressure switch. Moreover, the tailcap is reshaped to fit the remote pressure switch more securely.
>>Olight Perun 2 Black
✔Multi-functional flashlight with max 2,500 lumens and a 166-meter beam distance
✔Aluminum alloy body with new knurling design for both style and enhanced grip
✔Large silicone switch on the head for convenient and simple operation
✔Hand-held, head-mounted, or attached to a strap for hands-free use
Go to the homepage and have a look!
