Buying a flashlight for someone else is easier if you picture what they do after dark. At camp, they may need to light up a table or dig through the back of a car. On a night walk, they may want to see the next trail marker from where they stand. Those tasks call for different beams, and they offer a good starting point for picking between ArkTac and ArkTac Ultra.
For camping and van trips, look at ArkTac
The ArkTac’s PureFlood beam spreads light across the area just in front of you. It can light a camp table, the ground beside a tent or the back of a car while you unload. Olight rates the medium floodlight setting at 200 lumens for 6 hours. When only a little light is needed, the low floodlight setting is 15 lumens.
The ArkTac weighs 136 g with its battery and is 17 mm thick without the clip. For someone who always keeps a light in the same pocket or compartment, those dimensions help you judge whether it will fit.
For night walks with longer sightlines, compare ArkTac Ultra
On an open path, a focused beam can help you see a sign or the entrance to a campsite from farther away. Olight rates the ArkTac Ultra’s spotlight Turbo at up to 1,800 lumens and 215 m of maximum beam distance. The output steps down after the initial peak. These are manufacturer ratings measured indoors at 25 °C under ANSI/NEMA FL 1-2019, and what you see outdoors depends on conditions.
The Ultra also has a floodlight for seeing roots or stones close to your feet. It weighs 140 g with the battery and has an OAL 2 aluminium body.
Think about how they will recharge it
Both flashlights accept USB-C and MCC4 magnetic charging. A recipient who already carries a suitable USB-C charging cable can use it with either model. Someone who likes a dedicated charging spot could keep the magnetic cable there. Check the local listing for what comes with the version you choose.
Olight ArkTac
Broad floodlight for nearby areas and a focused spotlight for distant points.
Olight ArkTac Ultra
OAL 2 body and a spotlight rated by Olight at up to 1,800 lumens in Turbo.
Frequently asked questions about giving an ArkTac
Is there a dim setting for finding something in a tent?
Both models have a 1-lumen white moonlight mode. You can start there when looking for something close to a sleeping bag and turn up the brightness if needed.
How long can the floodlight run around camp?
Olight rates both models for 6 hours at 200 lumens on medium floodlight and 72 hours at 15 lumens on low floodlight. Actual runtime varies with conditions.
How water resistant are the two lights?
Both are rated IPX7. That rating covers temporary immersion under defined test conditions.
Choose for the person who will use it
For someone who spends evenings around the campsite or the back of the car, start with the ArkTac. If they often use a focused beam on longer night walks, compare the Ultra. Before you order, confirm the selected version, what comes in the box and any Black Friday terms shown by the local shop.
