The ArkTac Ultra puts a broad floodlight and a focused spotlight in one flat flashlight. Which charging cable comes in the box, and how long does the spotlight maintain peak output? The answers below come from Olight’s box contents and product specifications.
What comes with the ArkTac Ultra?
Olight’s standard box list shows the ArkTac Ultra flashlight, an MCC4 magnetic charging cable and a user manual. The flashlight also has a USB-C port, so you can charge it through that port with a suitable cable.
The OAL 2 aluminium body measures 135.6 × 29 × 17 mm. The 17 mm thickness excludes the clip, and the flashlight weighs 140 g with its battery. The front dial selects the light source, and the central button adjusts brightness. Separate indicators show the brightness setting and remaining battery charge.
How long does the spotlight hold 1,800 lumens?
The spotlight reaches its rated 1,800-lumen peak in Turbo mode. Olight gives this mode a maximum beam distance of 215 m. The specification shows about 3 minutes at 1,800 lumens, followed by about 100 minutes at 600 lumens and 45 minutes at 200 lumens.
| White-light mode | Olight’s output and runtime ratings | Useful for |
| Spotlight Turbo | 1,800 → 600 → 200 lumens, approximately 3 + 100 + 45 min. Rated maximum beam distance of 215 m. | Lighting a specific point at a distance. |
| PureFlood high | 1,300 → 500 → 200 lumens, approximately 3 + 105 + 45 min. Rated maximum beam distance of 72 m. | Lighting a wider area in front of you. |
| Medium | 200 lumens for approximately 6 hours on either beam. | Choosing the light pattern you need at a steady setting. |
| Low | 15 lumens on both beams. About 72 hours on floodlight and 60 hours on spotlight. | Using a low output when conditions allow. |
Olight measured these figures indoors at 25 °C using ANSI/NEMA FL 1-2019. Temperature and airflow can affect actual runtime. The photos show the flashlight in use.
How do the beams differ at 200 lumens?
Both beams produce 200 lumens on medium. Floodlight spreads it across a larger area, such as a work surface or the steps in front of you. Spotlight concentrates light in a smaller area, such as a sign at the far end of a path. Choose the beam by what you need to see, then compare runtime at the setting you expect to use.
Frequently asked questions about the ArkTac Ultra
Does the standard ArkTac also reach 1,800 lumens?
The standard ArkTac is rated at up to 1,700 lumens in spotlight Turbo. The 1,800-lumen rating is for the ArkTac Ultra.
Does the 17 mm thickness include the clip?
The 17 mm figure is for the body. Allow extra space for the clip if the flashlight will sit in a fitted compartment.
Is magnetic charging the only option?
The ArkTac Ultra supports USB-C charging as well as charging with the included MCC4 cable. The local listing provides the box contents for the variant you select.
Match the beam to your most common task
For a nearby surface, compare the PureFlood settings. If you regularly need to light a point farther away, compare the spotlight levels and their runtimes. Check the product listing for the exact contents supplied with your chosen version.
