Quick answer
Choose Oclip 2 Pro when a bag strap, shelf or bonnet gives you a secure mounting point but faces away from the job. Its tilting head and rotating clip let you aim without moving the clip. Keep Oclip Pro if its fixed beam already lands where you need it.
| What to compare | Oclip 2 Pro | Oclip Pro |
| Aiming once attached | Head tilts up to 115°. Clip rotates 360°. | Fixed head and clip. Aim by moving or remounting the torch. |
| Hands-free mounting | Clip up to 14 mm, magnetic clip and base, and hanging point | Clip up to 14 mm, magnetic base, and hanging point |
| Beam choices | White flood, white spot and red | White flood, white spot and red |
| Peak flood and max. spot range | 530 lm flood Turbo, 125 m spotlight | 500 lm flood Turbo, 120 m spotlight |
| Charging | USB-C or compatible magnetic charging | USB-C |
| Manufacturer protection ratings | IP66, 2 m drop test | IPX6, 1.5 m drop test |
Which light fits the gear they already use?
If you’re buying for someone else, ask where they would put a clip-on torch before asking about brightness. The obvious anchor might be a cap brim, a pack strap or the inside of a steel cupboard. Have them point to the spot they need to see. If the anchor and the spot face different ways, an adjustable head will solve a problem they actually have.
Start with the task they repeat, whether it’s looking into the boot after a late commute, reading a camp stove label once the cooking area has cooled, or picking the right socket off the garage wall. A broad, low beam in the right place generally helps more than extra peak output pointed across the bench.
What does the moving head add?
The Olight Oclip 2 Pro has a head that tilts through 115° and a clip that rotates 360°. The clip rotation lets you turn the beam across the mounting surface. The hinge changes how far the beam points away from that surface. On a steel bonnet, for example, the magnet can stay on a flat patch while you angle the head down toward the part you’re looking at.
Olight Oclip 2 Pro
Adjustable clip-on torch
Aim from a secure fixing point
Choose the standalone Oclip 2 Pro in Mech Green or Nebula Violet on the Australian product page. Both colours have the same dual-axis adjustment and three light sources.
View Oclip 2 ProSet the direction before turning the white beam up. Rotate the mount until the light points along the bench, tilt towards the job, then open the flood at a low setting. When a tool or your hand casts a shadow, make a small change to the tilt before changing where the torch is mounted.
When should you clip, stick or hang it?
Clip onto a firm brim, strap or edge within the 14 mm opening. On a loose pocket, test how much the fabric sags when you bend. The clip’s opening measures what can fit. How well it holds depends on the shape and stiffness of the surface.
Use the Oclip 2 Pro’s base or clip magnet on a flat steel surface where the torch sits steadily. Check the panel first, since aluminium and plastic trim offer no magnetic hold. Where there’s a secure loop instead, hang it and test the direction before you start. A pendant that swings as you move works better for lighting a small area at camp than for lining up a fastener.
When do flood, spot and red help?
Use white flood for shelves, labels and tools at arm’s length. Olight rates the Oclip 2 Pro flood at 530 lm for roughly the opening minute of Turbo before a step down to 300 lm. Start low, especially near pale walls, polished tools or a windscreen. Aiming across the work instead of straight at it can move a bright reflection out of your eyes. (Source: SafeWork NSW guidance on glare and lighting position.)
Switch to spot when the thing you want to see is farther away, such as a campsite marker or a toolbox on the opposite side of a shed. The Oclip 2 Pro’s rated 125 m is a maximum spotlight beam distance. Reading lettering or spotting a low-contrast object in dust or rain takes more usable light at the target.
Try low red for finding a familiar zip or key without lighting the whole tent. White light suits small print, colour-coded parts and unfamiliar footing better. At a shared campsite, aim the torch down as you turn it on.
When does the original Oclip Pro make more sense?
The Olight Oclip Pro is the simpler choice when a secure mounting point already faces the job. Its fixed head has a flood setting rated up to 500 lm, a spot rated up to 120 m, and a dedicated red light. Use its rotary selector to choose the light source, then operate that light with the side switch. On a firm forward-facing strap, you can clip it in place and keep your hands free.
Olight Oclip Pro
Fixed-head clip-on torch
Keep a simple setup for repeat jobs
Clip onto a secure edge that already faces the work and switch between flood, spot and red as needed. The light recharges over USB-C.
View Oclip ProIf you already carry one, try clipping it higher on the same strap or onto the edge of a different pocket. If you can find a natural position that holds through the whole job, the original torch covers it. If you keep moving it between near and far tasks, the second generation saves you from repeatedly finding another attachment point.
How does each torch fit an Australian summer setup?
- Late commute: A stiff backpack strap often points towards the path, which suits the Oclip Pro. When you stop to reach a lock down low, tilt the Oclip 2 Pro towards your hands without turning the whole pack around.
- Garage check: For an engine bay or recessed shelf, first find a stable steel mounting point. The Oclip 2 Pro lets you sweep light down below that surface while keeping both hands available. Switch to lower output if shiny metal throws light back at you.
- Car camping: Clip low on the boot opening if there’s a firm lip, then set a broad beam across the gear. At camp, leave a separate torch where you can find it after dark. For an extended walk on uneven tracks, carry a head torch as your main light.
NSW National Parks puts a torch alongside maps, water and first aid on its bushwalking packing list. A clip light can fill a different role as a spare or as task lighting around camp. (Source: NSW National Parks bushwalking safety and packing guidance.)
What do the durability ratings cover?
Olight reports 10,000 cycles each for the Oclip 2 Pro’s head tilt and clip rotation. Its IP66 and 2 m drop ratings apply to controlled manufacturer tests. The original Oclip Pro has an IPX6 water rating, a 1.5 m drop rating and a separately rated 10,000-cycle clip opening test. Those cycle counts describe three different movements, so compare the tilt and swivel on their own merits.
The IP66 rating applies to dust and water jets. Both models are best treated as splash- and rain-resistant torches for everyday work. Check that the charging cover is seated before exposed use, and dry the torch and the port before connecting a cable. Retest your grip after moving a mounting point or knocking the light.
What should you check before giving or upgrading?
- Choose Oclip 2 Pro if a fixed clip often faces away from the area that needs light. Choose Mech Green or Nebula Violet by preference. The colour choice leaves beam output and aiming unchanged.
- Choose Oclip Pro for a simple repeatable setup where the strap or surface points the right way. A lower weight and fixed head can suit a firm shirt or cap brim.
- Keep your torch if changing the clip position solves the problem. For longer reading or walking, add a dedicated head torch or stable area light when the job calls for one.
- Confirm the listing before ordering. The shared product page includes standalone and Premium options. Check the exact colour and package contents if a charging dock matters.
Frequently asked questions
What is the main difference between Oclip 2 Pro and Oclip Pro?
The Oclip 2 Pro has a 115° tilting head and a 360° rotating clip, letting you aim after mounting. The Oclip Pro has a fixed head and clip. Both have a white flood, white spot and red light, so the upgrade matters most when your mounting point faces the wrong way.
Are Mech Green and Nebula Violet different in performance?
They are colours of the standard Oclip 2 Pro. Both offer the same three light sources and dual-axis aiming. Check the variant selector for the standalone torch and review the box contents if you’re considering a package with a charging dock.
Will the Oclip 2 Pro magnet stick to my car bonnet?
The magnets need a suitable ferromagnetic material, such as steel. Many panels and trims are aluminium or plastic. Try the magnet on a stable patch with the torch off and check how well it grips before working. A firm edge or hanging point gives you another way to mount it.
