Are you looking for a perfet tactical light with high lumens for your incoming outdoor activities? Good News, we just select our Best-selling flashlights over 1000 lumens and 1000 beam distance for you! They are all perfect outdoor lighting tools that are suitable for hunting, fishing, outdoors activities search and rescue, law enforcement and so on.
No 1. Olight Javelot Turbo Black 1300m Hunting LED Torch
✦Great beam distance: Maximum beam distance of 1,300 metres making it the new king of throw.
✦Integrated battery pack: The battery pack comprises two 5000mAh 21700 batteries. It allows for longer runtime and quick replacement.
✦Two versatile switches: A tail switch to access 1,300-lumen or 15-lumen output directly; a side switch to cycle through 4 output settings.
✦Enhanced safety: The upgraded tail cap, same as that of Odin, fits securely with the lockable ROD remote pressure switch.
3-color indicator: The indicator at the center of the side switch clearly displays the battery life with a green, orange, or red color.
✦Tower-shaped tube body provides comfort and a firm grip for superior performance.
✦Magnetic tail cap: Functioning as a charging port or magnetic pressure switch mount.
✦High waterproof quality: IPX8 waterproof rating protected against continuous submersion over 1m for up to 30 minutes.
No 2. Olight Warrior X Pro 2,100 lumens rechargeable tactical LED torch
✦ High lumens and long runtime: Max 2,100 lumens, 500-meter throw and max 8-hour runtime powered by a customized 5000mAh 21700 lithium battery
✦Hard and waterproof: Passed 3-meter drop test and IPX8 waterproof protected against continuous submersion over 1m for up to 30 minutes
✦Fast charging effiency: Includes a MCC3 fast charging cable with a 2amp output, 2x the speed of previous models
✦ Upgaded version: Redesigned raised tail switch for an unprecedented intuitive operation experience
✦ Special colour-made: Made in nomal colour Black and the Desert Sunset in limited amount, which makes your light special enough
No 3. Olight M3XS-UT Javelot Rechargeable Kit
✦ High lumens and great beam distance: Max 1200 lumens with a max beam distance of 1000m powered by a customized 2600mAh 18650 batteries
✦ Appearance feature: The M3XS-UT features a large diameter reflector with a dedomed CREE XP-L LED
✦ Different modes: The torch has three brightness levels ranging from 3 to 1200 lumens plus a strobe mode.
Note: This kit from Olight includes 2 x 18650 batteries and a charger all in a hard carry case.
The M3XS-UT retains the tail cap switch design from the M3X for tactical operation with an added side switch on the head of the flashlight that allows easy mode switching. Milled from aircraft-grade aluminum with a Mil-Spec Type III hard-anodized finish, the M3XS-UT Javelot is ideal for search and rescue, law enforcement, industrial, outdoors, and emergency preparedness.
These three tactical torches recommended above are all our bestsellers with over 1000 lumens and 1000 beam distance, which can fully meet your demand for high lumens. Please be advised see more fair reviews from other buyers and hesitate to add them into your bags!
