The Warrior X turbo is a tactical flashlight Australia that produces a far-reaching beam of light. In its compact size, the Warrior X turbo delivers a highest output of 1,100 lumens, a highest throw of 1,000 meters and a highest run time of 12.5 hours. It has many features from the Warrior X series. The aggressive and simple design confirms its tactical identity. The magnetic tail switch also helps as a connection port for the magnetic charging cable and the magnetic remote pressure switch. Further, the tail cap has been reshaped to better fit the external force switch. With amazing performance and rich accessories, the Warrior X Turbo is a perfect lighting tool for search, hunting, rescue, outdoor activities and law enforcement.
Technical specs
· Maximum brightness: 1100 lumen
· Peak beam intensity: 250000 cd
· Peak beam distance: 1093 yards
· Impact resistance: 1.5 m
· IP rating: IPX8 waterproof
· Weight: 249g (including battery)
Mode
Mode 1 will run at 1100 lumens for 6.5 minutes before moving to 600 lumens with an extra runtime of 105 minutes – this is to stop the LED overheating, it will then move to 300 lumens, with a further run time of twenty-seven minutes, before finally moving to 150 lumens for another fifty-two minutes.
In the box
· MCC3 Magnetic USB charging cable
· Warrior X turbo
· Lanyard
· Silicone tactical grip ring
· Holster
· User manual
Features
Long throw tactical flashlight
The Olight Warrior X Turbo is the new edition of the best tactical flashlight Warrior X line. Brighter with longer runtime and throw, the Warrior X turbo emits up to 1100 lumens at an amazing throw distance of 1000 yards. Powered by a 5000mh 21700 Li-ion battery, this super throw is furnished with 100 percent quicker speeds and the capability to run for up to 12.5 hours, providing you more time to use the light.
Durable and robust
This light is made of aluminum alloy body, IPX8 waterproof rating, and 1.5 meter impact resistant rating. A perfect tool for search, hunting, and rescue, and law enforcement activities, the Warrior X Turbo can be paired with optional RWC magnetic remote switch for extra applications.
Simple to use
Just like its predecessor, the Warrior X Turbo is simple to use and perfect. Just click the raised tail switch button to cycle through the 2 output modes. To charge, place the magnetic charging cable onto the tail switch. The Warrior X turbo contains the special vibration battery indicator first introduced by the Warrior X.
21700 battery with vibrating battery indicator
The customized 21700 battery specs a 5,000mAh capacity and provides 12.5 hours of runtime. A special vibrating battery indicator alerts you to many intervals, and the added MCC3 magnetic charging cable uses a 2A for lighting fast charging.
Clip
The Warrior X turbo has a detachable stainless steel clip that can be used to link the flashlight to items such as utility belt.
Body
The torch body has a textured pattern, this provides an extremely firm grip – even if your hands are wet, you would not find the flashlight slipping.
More features
· 21700 battery provides 12.5 hours of runtime and charges quickly with MCC3 cord
· Vibrating indicator point out you progressively of low battery levels
· Rated IPX8 waterproof, 1.5m drop resistant, and 2m submersible
End words
The Olight Warrior X Turbo comes with a top performance LED and is run by a one customized 5000mAh 3.6V 21700 rechargeable lithium battery with a highest output of 1100 lumens.
It has a magnetic tail switch that also serves as the connection port for magnetic remote pressure switch and magnetic charging cable.
It is described by Olight new tactical flashlight that generates a far-reaching light beam with a highest runtime of 12.5 hours.
Just connect the magnet to the base of the Warrior X Turbo and plug the USB with the computer or the mains using a perfect USB adapter. The indicator torch on the magnet will go red while charging is in progress and turn green while charging is full.
