- What Is the Oclip Pro S?
- Five Light Sources Explained
- Key Features
- Who Is the Oclip Pro S For?
- Pros and Cons
- Conclusion: A Versatile Tool for Everyday Carry
- Frequently Asked Questions
When heading into the Australian bush or managing daily tasks, weight and versatility become the most critical factors for your gear. The Olight Oclip Pro S clip-on torch emerges as a premier solution for those seeking a lightweight hiking clip-on light that refuses to compromise on power. This multi-function EDC light integrates five distinct light sources into a chassis that weighs only 53 grams, offering a hands-free lighting experience that traditional flashlights simply cannot match.
The Oclip Pro S AU represents the evolution of portable illumination. It is not just a flashlight; it is a 5-in-1 lighting system designed to adapt to various environments. Measuring just 57 x 28 x 27 mm, it fits comfortably in the palm of your hand or securely on your outdoor gear.
Overview of This Multi-Function Clip Light
This best multi-purpose clip light stands out due to its construction from 6061 aluminum alloy, ensuring aerospace-grade durability without adding bulk. It serves as a primary light source for EDC (Everyday Carry), a safety signal for outdoor activities, and a specialized tool for professional inspections.
The true strength of the Oclip Pro S AU lies in its versatility. It offers a comprehensive lighting array that handles everything from long-range visibility to subtle night-time signaling.
White Floodlight for Area Illumination
For close-up tasks like searching through a backpack or setting up a tent, the white floodlight provides an even, wide beam. It eliminates harsh hot spots, making it easier on the eyes during prolonged use in confined spaces.
White Spotlight for Long-Distance
When you need to see what lies ahead on the trail, the spotlight delivers up to 600 lumens with a max throw of 80 meters. This performance is impressive for a device of this size, ensuring you can identify obstacles or trail markers from a safe distance.
Red Light for Night Vision
The red light mode is essential for maintaining natural night vision. Whether you are night fishing or simply checking a map without disturbing others, the red beam provides enough light to see without the blinding glare of white light.
Green Light for Map Reading
The green light source offers high contrast, making it ideal for reading topographical maps. It is also an excellent signaling tool, as green light is highly visible to the human eye over long distances.
UV Light for Inspection
A standout feature is the pure 365 nm UV light. This clip light with UV and red light is perfect for detecting counterfeits, inspecting cleanliness in hotels, or finding leaks during mechanical repairs.
Key Features
Efficiency and ease of use define the Oclip Pro S. Every design choice focuses on making the user's life easier during high-pressure situations.
Magnetic Base for Mounting
The integrated magnetic base allows the light to snap onto any metallic surface. This transforms the Oclip Pro S into an instant work light, providing stable illumination for hands-on tasks where holding a torch is not an option.
Strong Spring Clip for Hats and Straps
The heavy-duty spring clip is tested for over 10,000 cycles. It attaches securely to hat brims, backpack straps, or pockets, providing reliable hands-free light for active movement.
USB-C Rechargeable
Standardized USB-C charging means you can power up using the same cables as your modern devices. With a max runtime of 144 hours in moonlight mode, the Oclip Pro S AU remains ready for extended trips.
IPX6 Water Resistance
The IPX6 rating ensures the device survives heavy rain and splashing. For the unpredictable Australian weather, this level of protection is vital for any lightweight hiking clip on light.
This tool adapts to a wide spectrum of users, each finding value in its specific lighting modes and mounting options.
Campers and Hikers
Weight is the enemy on long treks. The Oclip Pro S provides a lightweight solution that clips directly to your gear, keeping your hands free for trekking poles or climbing.
Mechanics and Tradespeople
For those working in dark engine bays or crawl spaces, the combination of a magnetic base and a 365 nm UV light is a massive advantage for identifying leaks or inspecting components.
Dog Walkers and Night Runners
Safety requires being seen. The RGB flashing modes allow runners and dog walkers to mark their location, ensuring visibility to motorists and other pedestrians.
Pros and Cons
| Pros | Cons |
| Ultra-lightweight at only 53g | Maximum throw limited compared to larger torches |
| Five versatile light sources (White, Red, Green, Blue, UV) | Side switch may require a learning curve for gloves |
| Reliable 144-hour maximum runtime | Battery is built-in and not user-replaceable |
| Strong magnetic and clip mounting options |
The Olight Oclip Pro S clip-on torch is more than just a lighting accessory; it is a critical piece of safety and utility gear. By combining a 600-lumen output with specialized UV and RGB modes, it effectively replaces several bulky tools in your kit. Whether you are navigating a trail at dusk, inspecting a vehicle, or simply need a reliable everyday light, the Oclip Pro S AU delivers professional performance in a compact, rugged package. Its ability to provide consistent hands-free light makes it an essential addition to any outdoor enthusiast's collection.
How long does the Oclip Pro S take to charge?
The Oclip Pro S utilizes fast USB-C charging and typically reaches a full charge from empty in approximately 1.5 to 2 hours.
Can the Oclip Pro S be used as a headlamp?
Yes, thanks to its strong spring clip, it can be securely attached to the brim of a baseball cap, functioning as a lightweight and effective headlamp for hiking or working.
Is the UV light powerful enough for forensic use?
The 365nm UV light is professional-grade, making it suitable for checking currency, identifying organic stains, and mechanical leak detection.
What is the warranty on the Olight Oclip Pro S?
Olight typically offers a Lifetime warranty for the Oclip series, covering defects in material and workmanship under normal use conditions.
