Marauder Mini Review
A Mini Beast with Everything: Flood/Spot/RGB
Overview
Introduction
What's in the box
Batteries and charging
Lighting modes
RGB lighting modes
Led and Beam
Beamshots
Application
Comparison with Marauder 2
Video
Price and discount
Introduction
A lot of people love the Marauder Mini flashlight. The throw is fantastic, the output is good, and the fact that the light is available in red, green, or blue just makes it even more fun! It's a powerful rechargeable dual-beam LED flashlight with both flood and throws. With the toggle switch in the middle of the body, you can quickly choose spotlights or floodlights, while the rotary knob on top allows you to adjust brightness.
The flashlight's body surface is covered with 270-degree silicone for a more comfortable and stable grip. With the hidden lanyard hole design, the device can be easily stored, carried, and used on a regular basis. Smaller in size but still powered like a beast, the Marauder mini is a must-have for search & rescue, hunters, and all outdoor enthusiasts.
Also, there are nice stretchy holster and lanyard available for the Marauder Mini. It can be taken hands-free. This is why Marauder Mini is a good choice for the most powerful edc flashlight.
GENERAL DATA | |
Max Output | 7000 lumens |
Max Runtime | 43.5 Hours |
Max Light Intensity | 90000 cd |
Max Throw | 600 meters |
Powered By | 24Wh 32650 rechargeable lithium battery |
| Light Source | High-Performance Cool White LED |
| Dimensions | Length: 5.12in/130mm Head Diameter: 2.58in/65.6mm Body Diameter: 1.73in/44mm |
| Weight | 16.3oz/462g (Battery Included) |
| Body Material | A6061-T6 Aluminum Alloy |
| Warranty | Olight’s 5-Year Warranty |
| WATERPROOF | IPX8 |
| DROP TEST | 1.5M |
What's in the box?
Marauder mini (Battery Included) x 1
MCC3 Magnetic Charging Cable x 1
Lanyard x 1
Holster x 1
User Manual x 1
Powered by a customized 24Wh 32650 rechargeable lithium battery, it offers an extended runtime. The tail cap of the Marauder Mini can be removed, unlike the Marauder 2. That means the cell can be replaced, so it can be used again and again.
It is compatible with Olight's MCC3 magnetic charging cable. It's convenient for charging. You don't have to worry about battery usage at any time, anywhere. It only takes about 4 hours from empty to full.
Lighting mode
There are two powerful beam options for this LED array: a spotlight beam of 600 meters max throw or a floodlight beam of 7,000 lumens max output from the 9 LEDs surrounding the central LED. Using a simple toggle switch, you can choose either spot or flood mode, and an intuitive rotary knob lets you choose from seven brightness levels.
RGB lighting modes
Three RGB color LEDs are uniformly distributed around the converging lens, making it suitable for use on any occasion.
The Red light is perfect for emergency signaling. It can enhance safety if you experience car trouble or help you be found quickly if you are lost. It can also be used to preserve night vision. The green light really helps to preserve night vision. It's also great for increasing your visibility and has been shown to calm animals, making it a great choice when walking your dog at night. Blue light can be used for spotting, tracking fishing, and animals during outdoor activities.
Led and Beam
Following the Marauder 2's lens design and composed of 9 LEDs surrounding the center, it enables seven brightness levels that provide 200-7000 lumens. A large round LED has been added to the center, offering a 600-meter spotlight beam. A built-in thermal sensor and cooling fins ensure safety in case of overheating and lens obstruction.
Beamshots
Floodlight mode
Spotlight mode
In Marauder mini, the Spot beam has been shaped in a circular pattern instead of a square compared to the Marauder 2.
RGB mode
With the Marauder mini, you get RGB light as well as a color indicator light.
Application
A good feature of the Marauder Mini is its ability to run multiple applications at once. Being a 7000-lumen EDC flashlight that would be a great asset to have when going camping, especially during setup or pack up of the campsite in the middle of the night. Besides that, it would also be great to have security, Law enforcement, and emergency responses.
Compared to the Marauder 2, this light is more compact and holds a lighter weight at only 16oz, which comfortably fits in your hand and feels exceptionally balanced. In comparison to Marauder 2, what are the upgrades? Firstly. Marauder mini has RGB light and a light color indicator. Secondly. A vibrating charge indication is available for the Marauder mini. And, It uses bottom magnetic for charging. Also. Spot beam shape changed from square to circular.
| Item | Marauder 2 | Marauder Mini |
| Max. Performance (lumens) | 14,000 | 7000 |
| Beam Distance(m) | 800 | 600 |
| Beam Distance(ft) | 2,625 | 1968 |
| Mode Operation | Rotary Knob Switch & Toggle Switch | Rotary Knob Switch |
| Light Intensity (candela) | 99,200 | 90,000 |
| Compatible Batteries | Customized Three 3.6V 5000mAh 21700 Rechargeable Lithium-ion Batteries | Customized 24Wh 32650 rechargeable lithium battery |
| Charge type | USB-C Charging Cable | MCC3 magnetic charging cable |
Weight (g / oz) | 750 / 26.5 | 462 / 16.3 |
Length (mm / in) | 140 / 5.51 | 130 / 5.12 |
Head Diameter (mm / in) | 79 / 3.11 | 65.6 /2.58 |
Body Diameter (mm / in | 53 / 2.09 | 44 /1.73 |
Use | Search and Rescue, Outdoors, Military, Law Enforcement | Outdoors, Search and rescue, Law enforcement |
| Original Price | $434.95 | $299.95 |
| Black Friday Price | $ 326.21 (25% OFF) | $ 194.97 (35% OFF) |
Video
Price and discount
The Original of the Marauder Mini is 299.95. But the good news for you now. Since we are in Black Friday Super Sale, there will be a 35% Off discount available for the Marauder Mini. Right now you only need to pay $194.97 can get it. what are you waiting for?
