The Baton 3 pro max is a compact but strong EDC torch that delivers up to 2,500 lumens, ensuring you have sufficient light for any occasion. The optical system has been optimized, permitting the hidden proximity sensor to still save you from potential dangers of lens obstruction or accidental activation, while solving the issue of hypersensitivity. Users can disable the sensor permanently or temporarily. It also features a latest way to check battery level, just immediately shake the torch to activate its battery indicator. The battery level is clearly shown with this easy shake and without needing to turn on the torch. Anyway, the Baton 3 Pro max will bring you amazing experience as a great EDC flashlight.
Tech specs
· Beam distance: 145 metres
· Maximum performance: 2,500 lumens
· Battery: Customized 5000mAh 3.6 21700 lithium-ion rechargeable battery
· Body diameter: 26mm
· Length: 114mm
· Charge type: MCC3 Charging cable
· Waterproof: IPX8
Features
Brighter and more strong
The flashlight is a strong and versatile tool that can be used for a range of activities. It is run by a 500mAh battery that delivers up to 2,500 lumens of maximum output. This means that it can give a bright, focused beam that can be used to illuminate objects at a great distance. The torch also has a runtime of up to sixty days, which means that it can be used for an extended period of time without any charging. This makes it perfect for hiking, camping, and other outdoor activities.
Proximity sensor
The flashlight also specs a brand-new upgraded proximity sensor. This sensor helps to save the user from accidentally shining the torch in their eyes. The sensor is also adjustable, so you can pick how sensitive it is. This makes it perfect for use in a range of atmosphere, from dark forests to crowded streets.
User-friendly interface
The enlarged and recessed side switch is now simple to operate, while simultaneously decreasing the chance of accidental activation, providing a better user experience. The enlarged side switch makes it simple to press and grip for longer periods of time, while the recessed design stops it from being accidentally activated in your bag or pocket. This gives an improved user experience by making it simple to use the torch without accidentally activating it.
Light levels
The Baton 3 pro max has 6 different light modes that are simply accessed by pressing and gripping the side switch in a range of combinations. Here is a fast overview of the output and guessed run time for each level:
Moonlight mode
When the torch is off, you can press and grip the switch to activate moonlight mode which has an output of one lumen. This mode is best in conditions where you don’t want to light up the globe and are finding your way around a campsite, your tent or at home when you don’t want to wake the rest of the family. With a very low output, you should expect a completely charged battery to last for sixty days when using this mode alone.
Low mode
This mode is best when you need more light on the trail or around the campsite. With an output of fifteen lumens and a runtime of 180 hours, the flashlight could simply last for a weeklong multi-day hike on a one charge.
Medium mode
For darker lights, when the moon is fully hiding, the medium mode will help glow up your surroundings with 120 lumens output.
High mode
High mode will output 800 lumens for around four hours before dropping to an output of 120 lumens for approximately 1.5 hours.
Turbo
You can simply light up objects at 145m away so if you are searching for signalling for help or wildlife, this is the mode to use. Do bear in mind though that this mode, at 2,500 lumens, will last for one minute of run time before dropping mechanically to an output of 800 lumens for around four hours.
Strobe
When it comes to signalling, there are globally recognised methods such as SOS where you flash the light quickly 3 times, slowly 3 times, then quickly 3 times. Some LED pocket torch have this SOS mode built in, but the Baton 3 Pro max does not. Instead, it has a strobe mode that flashes quickly and brightly.
