Hey there, have you heard the exciting news? We just unleashed the latest torch - the Javelot long-range torch.
I'm thrilled to introduce the newest addition to Olight's lineup. Let's see what makes Javelot sight to behold
EDC Redefined: Extreme Distance Coverage
Class-leading 730-meter spot beam and an incredible 134,000 candela cut through the night.
Experience unparalleled lighting performance with the class-leading 730-meter spot beam, allowing you to illuminate vast distances with ease. With an incredible 134,000 candela, this powerful beam effortlessly cuts through the night, providing exceptional clarity and visibility in even the most challenging environments.
Sleek Look, Solid Hold
Just under half a pound, with pronounced knurling, it's secure and stylish.
Weighing just under half a pound, this compact and lightweight tool is designed for convenience and portability without compromising on durability. The pronounced knurling not only enhances its grip and handling but also adds a touch of sophistication to its overall design.
Dual Switches for Any Setting
Designed for flexibility, made for practicality.
Crafted with adaptability in mind, engineered for everyday functionality. Embodying the essence of utility, this creation goes beyond mere convenience; it is an embodiment of ingenuity that effortlessly integrates into diverse settings.
6 Side Switch Accessible Lighting Modes
Turbo:1.350~600 lumens
High: 650-250 lumens
Medium: 150 lumens
Low:15 lumens
Moonlight: 0.5 lumen
Strobe: 13 Hz
Quick Deployment Tail Switch
Programmable for tactical use.
For tactical professionals, having a programmable tail switch means having the power to optimize the flashlight's functionality for different missions and environments. With the ability to store and recall preferred settings, the Javelot ensures that users can effortlessly transition between modes without compromising on performance or wasting valuable time.
Experience the 730-meter Throw
Step into a world of unparalleled illumination with the Olight Javelot and discover the true meaning of long-distance lighting. With an impressive throw distance of 730 meters, this powerhouse of a flashlight shines a beam of light that pierces through the darkness with breathtaking precision and clarity.
Convenient Carry Options
Included holster and clip for EDC & work and Reversible Two-Way Clip
With the inclusion of an included holster and clip, as well as a reversible two-way clip, the Javelot ensures that carrying this reliable flashlight is both effortless and customizable to individual preferences. Constructed from durable materials, the holster keeps the flashlight safe from the elements and potential damage, ensuring that it remains in optimal condition for extended use. In addition to the holster, the Javelot comes equipped with a clip that further expands. The clip enables convenient attachment of the flashlight to pockets, straps, or gear loops, allowing for quick and easy access whenever illumination is needed.
High-Capacity Battery
5000mAh battery takes your light further & Recharge with a snap, even when it's docked in the holster
The 5000mAh high-capacity battery ensures that your device's performance goes the extra mile, providing sustained power for extended usage. You can enjoy longer periods of uninterrupted usage without the need for frequent recharging, enhancing your overall user experience.
Turn Your EDC Into a WML
Mount it on your set-up together with a remote switch for greater control in night hunting or tracking.
Optional Accessories:
SROD-7 Magnetic Remote Switch
SROD Magnetic Remote Switch With Long Coil Wire
X-WM03 Magnetic Mount
By converting your EDC into a WML and pairing it with a remote switch, you can significantly enhance your readiness and effectiveness for nighttime pursuits. Transform your everyday carry (EDC) into a formidable weapon-mounted light (WML) system and elevate your capabilities for night hunting or tracking by seamlessly integrating it into your setup alongside a remote switch.
Made for the Outside
Drop resistance up to 1.5 meters & IPX8 waterproof to 2 meters for 30 minutes
With exceptional durability, Javelot can withstand drops of up to 1.5 meters without compromising its functionality. Additionally, boasting an IPX8 waterproof rating, this device can be submerged in water up to 2 meters deep for 30 minutes without any damage. Whether you're hiking through rugged terrain, exploring wet environments, or simply enjoying the great outdoors, our product's robust design ensures that it can handle whatever nature throws its way.
![[New Product] Illuminate Your World: Unveiling Javolet - Your New Lighting Essential](https://cdn.olightstore.com.au/image/javelot-long-range-torch-2-3gefsi.jpg@920w_518h_75q.webp)
