Build one household emergency kit for disasters using Australian Red Cross RediPlan. Clip an Oclip 2 Pro to the grab-bag strap for reading labels and finding supplies with both hands free. Add a handheld torch for clear routes, a shared light for blackouts and a small pouch for your local seasonal risks.
| Job | What to pack | What to check before storing it | Example |
| Cover essentials | Water, shelf-stable food, can opener, first aid, regular medicines and a printed plan | Scale food and water to everyone in the home. Confirm how much each person needs with your local emergency agency. | Core kit based on RediPlan |
| Keep both hands free | A clip-on light or head torch with a low white setting | The beam should stay on the job when you zip a bag, handle medication or control a pet lead. | Oclip 2 Pro |
| Aim farther on a clear, safe route | A handheld torch and its power supply | Check a useful low or medium setting and practise the controls before leaving it in the kit. | Seeker 4 Pro |
| Light a shared spot during a blackout | A dimmable area light | Check that the light can stand securely and that everyone can turn it on without a phone. | Sphere C |
| Signal and receive updates | A whistle, portable radio and the right spare batteries | Keep the whistle near the bag opening, and tune the radio to your local emergency broadcast station. | Olight Emergency Whistle and a battery radio |
What should every household emergency kit contain?
Put the supplies you could carry in a grab bag and keep bulk water and food alongside it. Include first aid, regular medication and a prescription list, a charged power bank and cables, a radio with spare batteries, cash, keys, contact numbers and essential documents in a waterproof pouch. Add items for babies, pets and anyone who uses mobility or medical equipment. Store a printed copy of your plan with the kit so everyone can find the meeting place and emergency contacts offline. (Australian Red Cross RediPlan resources)
| Checklist and scope | What it lists | What to do with your kit |
| Australian Red Cross RediPlan General household kit |
Pack a torch. The packing checklist also suggests a wind-up torch as an option. Get Packing checklist | Keep an independent light with the core supplies. |
| NSW State Emergency Service Power outages and evacuation |
The checklist lists a torch with spare batteries and a separate whistle. NSW SES emergency kit checklist | Keep spare power and an audible signal within reach. |
| Queensland State Emergency Service Storms, floods and cyclones |
The kit lists a battery or wind-up torch, extra batteries and waterproof kit storage. Queensland SES emergency kit checklist | Group light and spare power in protected pouches for wet weather. |
| NSW Rural Fire Service Bushfire preparation |
The list specifies a waterproof torch and spare batteries. NSW RFS survival kit checklist | Put the torch and spare power in the grab bag before the season. |
| Australian Red Cross Cool Kit Extreme heat and blackouts |
The checklist includes a torch, a power bank and cooling supplies. Cool Kit checklist | Plan lighting and cooling together if mains power fails. |
Keep the first light where you can reach it
Clip the Oclip 2 Pro to a firm strap at the top of the grab bag, where you can find its switch by touch. Open the bag, turn the clip until the light faces the opening, then tilt the head towards the contents. You can hold the bag steady and read a medicine label with both hands available. At a table, move the beam onto the printed household plan and start with a low white setting to keep reflections off the page.
Before you put the kit away, make sure the clip grips the strap with the bag open and closed. Try the wide beam while sorting supplies, then select the spot beam if you need to locate a latch or read a notice farther away from a safe position. Both movements can be made without changing where the clip sits. Keep the cable with the power bank and use the white mode for reading printed instructions or medication labels.
Put a whistle in the grab bag’s outer pocket for a sound signal that uses no battery. For a life-threatening emergency, call Triple Zero (000) if you can. (NSW SES emergency kit guidance) (NSW SES emergency contact guidance)
What changes in bushfire season?
Pack the items your fire service recommends before the season starts. NSW Rural Fire Service’s list includes a waterproof torch, spare batteries, a portable radio and woollen blankets. Put enclosed shoes and clothing recommended in your local bushfire plan where you can reach them quickly. Leave early in line with your plan and warnings. (NSW RFS emergency survival kit checklist) (NSW RFS guidance for preparing your household)
Keep a handheld torch near the grab-bag handle for a short look at a step, latch or other detail on a clear exit route. At a dry packing spot, its handheld beam can also reach a specific bag or compartment without moving the gear around. Start at a manageable brightness. Smoke can scatter the light back towards you and hide obstacles. Follow fire-service advice if smoke affects the route and keep your attention on leaving safely.
In Olight’s lab data, the 4,600 lm Turbo stage lasts about 2.5 minutes before stepping down. Use the setting you would normally run when planning how many hours you can cover. The maximum beam-distance rating describes the torch under test conditions. Visibility through smoke or heavy rain can be much shorter. Olight Seeker 4 Pro manual.
What should stay dry in flood season?
Store lighting, spare power and important papers dry. Put the torch and spare cells in separate sealed pouches so using the torch in rain does not expose every item in the pack. Look for a water resistance rating suited to your likely exposure and check the manufacturer’s instructions for covers, seals and charging after use. Olight rates the Oclip 2 Pro IP66 and Seeker 4 Pro IPX8 under its stated test conditions. Store the clip light with its charging-port cover closed. Use the dry bag for the whole kit regardless of the torch rating. Browse water-resistant torches.
If floodwater is on the route, turn back or stay at a safe location in line with emergency advice. Never enter floodwater on foot, on a bike or in a vehicle. Use the torch for ordinary tasks from a safe place, such as reading an evacuation notice or finding supplies while you wait for updates. (NSW SES flood safety guidance)
How do you light a long blackout?
For a storm or cyclone blackout, use a small area light in the room you’re sheltering in. Put it on a dry, stable surface away from the edge so several people can see a radio or documents without passing one torch around. During a cyclone, follow local instructions on whether to evacuate or shelter. If sheltering indoors, choose the strongest part of the building away from windows. (Get Ready Queensland cyclone, storm and flood guidance)
The Sphere C suits a small area such as a table with water and a radio. Learn the physical controls and choose a low white setting for background light. Leave a handheld torch free for moving between rooms and a clip light for reading labels or closing a bag.
During a heatwave, put the power bank and rechargeable lights somewhere cool and dry. Add the cooling supplies your household needs, such as an insulated bag, ice packs and a fan you can run during an outage. If anyone relies on powered medical equipment, put its backup-power and relocation arrangements in the household plan. (Australian Red Cross Cool Kit checklist) (Get Ready Queensland cyclone guidance for medical supplies)
If several people need to prepare food or read at a larger table, try a brighter portable lantern in that space before you pack it.
Which light setting fits each job?
Treat the figures below as manufacturer examples for planning. Use the lowest mode that lets you complete the task comfortably and budget for spare power. Check your exact setting against the Oclip 2 Pro product specifications, Seeker 4 Pro manual and Sphere C manual.
| Scenario and safe task | Starting light level | Olight-rated runtime in that mode | Water and storage decision |
| Bushfire preparation on a clear route | Seeker 4 Pro Low at 50 lm for a short directed check | 60 h on Low | IPX8 rated torch. Pack it with the dry exit kit and follow your fire plan. |
| Flood preparation or evacuation along a clear route | Seeker 4 Pro Medium at 300 lm if Low leaves steps unclear | 11 h on Medium | IPX8 rated torch. Keep the charging gear and backup light in a dry bag. |
| Storm or cyclone blackout, close work | Oclip 2 Pro white flood on Moonlight for locating items; raise the level for legible print | Up to 144 h at 1 lm on Moonlight, rated by Olight. Check the higher mode for the job before packing. | IP66 rated. Close the USB-C cover and store dry. |
| Heatwave blackout, low background light | Sphere C lowest white at 1 lm to mark a table or bedside | 40 h at 1 lm | IP56 rated. Use indoors on a stable surface and keep spare power cool and dry. |
Check the controls and beam in a dry room before an emergency. With a backup light on hand, switch off the room lights and see if you can find the kit, read a medication label and find your charging lead. Then show each person where both lights go. For a replacement, start with the setting and controls you need when you compare portable lights and torches.
How do you keep the kit ready through the year?
Set a reminder to check the kit each season, plus a quick check ahead of any forecast event. Before local bushfire season or summer heat arrives, check the fire or heat supplies. Before your local wet season, move the dry bag somewhere easy to reach and check that it seals. Queensland SES recommends keeping the emergency kit in an accessible waterproof container and checking it seasonally. (Queensland SES emergency kit guidance)
- Turn on each torch and radio, check the setting you use and make sure every cable works with the power bank. Include the charging holster if the torch needs it.
- Rotate food and water according to packaging or agency guidance, and check medicines and first-aid expiry dates. Update contact details, access needs and pet supplies when they change.
- Store spare batteries where their contacts cannot touch metal objects. Keep any button batteries out of children’s reach and choose devices with secure battery compartments.
- Inspect rechargeable gear for damage, swelling and heat exposure. Recharge it on a dry, non-flammable surface using equipment the manufacturer recommends, and unplug it when charged.
Pack a fresh set of compatible spare cells if your radio or backup torch takes them. A separate battery-powered backup helps when the rechargeable lights share one power bank. Allow lithium-ion equipment to cool before charging, and keep it out of a parked car in hot weather. (ACCC lithium-ion battery safety) (ACCC button battery safety)
What does your council’s disaster dashboard tell you?
Bookmark your local council’s disaster dashboard before a warning. Where a dashboard is provided, it can show road closures, outages and active evacuation centres. Look at the update time, then check which road and destination are open before you set out. Use Bureau of Meteorology weather warnings and instructions from state or local emergency services to decide whether to leave early, evacuate or shelter. (Get Ready Queensland council dashboard finder) (Get Ready Queensland advice during a disaster)
Brisbane’s map shows open evacuation centres and lets you tap a centre for its address. In Cairns, check the storm-surge zones and evacuation routes alongside road closures and flood cameras. Use the dashboard for your own council area and confirm accessibility or pet arrangements before leaving for a centre. (Brisbane City Council emergency dashboard) (Cairns Regional Council dashboard guide)
Write the key contact numbers on your printed plan and check which local radio station broadcasts emergency updates. Keep its frequency with the radio in case internet access drops. (Get Ready Queensland sources for local emergency information)
Frequently asked questions
What are 20 items in an emergency kit?
A useful Australian household checklist includes drinking water, shelf-stable food, a can opener, first aid, regular medicines, prescription copies, a torch, spare batteries, a radio, a charged phone, charging cables, a power bank, a whistle, cash, an emergency contact list, your household plan, copies of ID and insurance, a dry bag, protective clothing and sturdy shoes. Add supplies for pets and anyone who needs daily support.
What is a disaster preparedness kit?
It is the set of supplies your household keeps ready to manage a loss of power or services, or to leave safely when directed. Keep a core set for both situations. Put the essentials you would take with you in a carryable bag and store bulk water and food alongside it for sheltering at home.
What are 10 items in an emergency?
Start with drinking water, shelf-stable food, a can opener, first aid, regular medicines, a torch, spare batteries, a battery-powered radio, a charged phone and a power bank with the right cable. Keep a printed plan with the supplies so everyone knows where to find them and where to go.
