With the launch of the Baton 4, we continue to push the boundaries of portable lighting technology. Baton 4 is set to revolutionize the way we perceive portable lighting.
The Baton 4 represents a significant upgrade from its predecessor, the Baton 3. The Baton 4 stands as a pinnacle of innovation and advancement, surpassing its predecessor, the Baton 3, in every aspect.
What's Upgrade From Baton 3 and Perun Series
Baton 4 Wireless Charger VS Baton 3 Wireless Charger
Built on the success of the highly acclaimed Baton 3 edc torch, the Baton 4 represents a groundbreaking upgrade in terms of performance, convenience, and design. The Baton 4 is crafted from premium-grade aluminum alloy, making it both lightweight and durable. Its sleek design fits comfortably in your hand, with an ergonomic shape that ensures a secure grip.
Let's dive into the standout benefits and functionalities of the Baton 4 and Baton 4 Premium Edition.
Why Choose Baton 4:
Maximum output of 1,300 lumens& throw of 170 meters: Despite its compact size, the Baton 4 boasts a high-performance LED and TIR lens, delivering an impressive maximum output of 1,300 lumens and a beam reach of 170 meters.
Innovative laser micro-perforated indicator: The Baton 4 pocket flashlight features an innovative laser micro-perforated indicator that intuitively displays the remaining brightness and battery life. This upgraded element ensures users can effortlessly monitor their flashlight's status and better plan their usage.
Enhanced metal switch: An enhanced metal switch bolsters the Baton 4 with added robustness, making each press more solid.
Last up to 30 days with an upgraded rechargeable 650mAh lithium-ion battery: Gone are the days of bulky battery packs and tangled cords. It is powered by a customized rechargeable 650mAh lithium-ion battery and can last up to 30 days in Moonlight mode
The Convenience of Baton 4 Charging case:
Higher-capacity Battery: The accompanying charging case in Premium Edition houses a robust 5000mAh battery, offering the Baton 4 up to 190 days of runtime.
Control the flashlight without needing to retrieve it from the case: The charging case features a nifty display button, allowing users to fully control the flashlight without needing to retrieve it from the case.
Also supports storing and charging the Baton 3, S1R II, Perun Mini, and Perun 2 Mini: The case is not only compatible with the Baton 4, but it also supports storing and charging the Baton 3, S1R II, Perun Mini, and Perun 2 Mini. This compatibility amplifies its utility and flexibility.
Type-C input and output: With its universal Type-C port, you can easily charge the case or use it as a power bank to charge your mobile devices.
Basic parameters
| Baton 4 | Baton 4 PREMIUM EDITION | |
| LIGHT SOURCE | High-Performance CW LED | High-Performance CW LED |
| DIMENSIONS | Length: 2.48in/63mm Head Diameter: 0.83in/21mm Body Diameter: 0.83in/21mm | Baton 4 Length: 2.48in/63mm Head Diameter: 0.83in/21mm Body Diameter: 0.83in/21mm Charging Case Length: 2.56in/65mm Width: 1.26in/32mm Height: 3.46in/88mm |
| WEIGHT | 1.85oz/52.5g (Including Battery) | 6.84oz/194g (Including the case and the flashlight) |
| BODY MATERIAL | Aluminum Alloy | Aluminum Alloy (Baton 4) PC (Charging Case) |
| POWERED BY | 3.6V 650mAh 2.34Wh | Customized 650mAh battery (Baton 4); 5000mAh battery (Charging Case) |
| WARRANTY |
| IN THE BOX |
| MARKET APPLICATIONS | Camping & Hiking & Mountaineering & Household | Camping & Hiking & Mountaineering & Household |
| COLOR OPTIONS | (Black) (OD Green) (Regal Blue) (Candy Cane) | (Black) (OD Green) (Regal Blue) |
Extranary Benefit for Baton 4&Baton 4 Premium Edition
From 1:00 PM on 17/11 to 12:59 PM on 29/11 (AEDT), We are hosting a Baton 4 Quiz event where participants can have a chance to win a $5 OFF voucher code, available on all orders containing Baton 4 & Baton 4 Premium Edition. Let's get it now!
