Hey Guys! Have you got the news from us? We upgraded the Baton 3 Pro series. But first, just one quick question, have you guys tried the Baton 3 Pro yet? We hope so! Right now, in this article, we will examine the updated version of Baton 3 Pro Max. Is it worth the upgrade? Just follow my lead and find the answer.
Let's check out what's different between the Baton 3 Pro Max, Baton 3, and Baton 3 Pro (released in September 2022).
Baton 3 Pro Max
| Baton 3 Pro
| Baton 3
Release date | 01/2023 | 09/2022 | 03/2021 |
Brightness | 2,500 lumens | 1500 lumens | 1200 lumens |
Beam Distance(m) | 145 m | 175m | 166m |
Max. Runtime | 60 days | 120 days | 20 days |
Light Source | LED | LED | LED |
CCT | Cool White, Neutral White, Warm White | Cool White, Neutral White | Cool White |
Weight (g / oz) | 148g/5.22oz (Including Battery) | 103 g/3.63 oz (Including Battery) | 53.0 g /1.87 oz (Including Battery) |
Charge Type | MCC 3 Magnetic Charging Cable | Magnetic USB charge cable | MCC 1A Magnetic Charging Cable |
Compatible Batteries | Customized 5000mAh 3.6V 21700 Rechargeable Lithium-ion Battery | Customized 3200mAh 3.6V 18650 Rechargeable Lithium-ion Battery | Customized 550mAh 3.7V IMR16340 Battery |
Warranty | Olight’s 5-Year Warranty | Olight’s 5-Year Warranty | Olight’s 5-Year Warranty
Baton 3 Pro Max is the Max version of OLIGHT Baton 3 Pro. Based on the difference between them, let me show you why the baton 3 Pro max is worth the upgrade.
2500 Lumens - SHAKE I T !!!
EDC flashlight Baton 3 Pro Max is compact but powerful, delivering up to 2,500 lumens, so you'll have enough light for any situation. In terms of performance and physical upgrades, the Baton 3 Pro Max brings a lot to the Baton lineup. Its maximum output goes up to 2,500 lumens in turbo mode.
21700 5000mAh Battery
The Baton 3 Pro Max comes with a 21700 5000mAh battery. It provides a runtime of up to 60 days, plenty for long workdays or backcountry excursions. In addiction, with the easy-to-use MCC3 USB magnetic charging cable, it's fully charged in only 4 hours.
Upgraded Proximity Sensor
A hidden proximity sensor has been designed with an optimized optical system, helping it protect you without being oversensitive. The light ships with the proximity sensor on. In any case, the user is free to turn it off temporarily or permanently and then turn it back on when desired.
Three Color Temperature Options
Shake to Awake Battery Indicator
In addition, the flashlight has a new way to check the battery level: just shake it quickly to activate the battery indicator. You do not have to turn on the flashlight to see the battery level when you shake the device. If you shake the switch, an LED light within it will illuminate and flash for a second or two to tell you how much battery life remains.
Bigger Size
As we see from the image, Baton 3 Pro Maz is bigger than Baton 3 Pro. Baton 3 Pro Max is a Medium size, while the Baton 3 Pro is a small size for an EDC torch.
