Let's see what is different between Warrior Mini and S2R Baton II Pocket Flashlight
| WARRIOR MINI | S2R BATON II |
GENERAL DATA | ||
Beam Distance | 623ft (190 m) | 443 ft (135 m) |
Max Performance | 1,500 lumens | 1,150 lumens |
Charging Type | Charging Cable | USB Charging Cable |
Compatible Batteries | Customized 3500mAh 3.6V 18650 | Customized 18650 |
Max Light Intensity | Lithium Battery | 4,600 candela |
Light Source | 9,025 candela | Luminus SST-40 CW LED |
Lens / Reflector Type | | TIR Lens |
Mode Operation | High Performance LED (6000~7000K) | Side Switch |
Form / Size Factor | Tail Switch & Side switch | Medium size (Permanent Marker) |
Series | Series Warrior (Tactical, Military) | Series Baton (EDC, General Use) |
LIGHTING LEVELS | ||
LEVEL 1 | 1,500~500~170 lumens | 1,150~400 lumens |
Run time LEVEL 1 | 4+205+55 mins | 2 minutes + 230 minutes |
LEVEL 2 | 500~170 lumens | 400 lumens |
Run time LEVEL 2 | 218+50 mins | 4 hours |
LEVEL 3 | 120 lumens | 120 lumens |
Run time LEVEL 3 | 18 hours | 14 hours |
LEVEL 4 | 15 lumens | 15 lumens |
Run time LEVEL 4 | 150 hours | 100 hours |
LEVEL 5 | 1 lumen | 0.5 lumens |
Run time LEVEL 5 | 5 days | 60 days |
Strobe | Yes | Yes |
TECHNICAL CHARACTERISTICS | ||
Waterproof | IPX8 | IPX8 |
Weight | 3.7 oz (105 g) | 3.47 oz (98.5 g) |
Length | 4.19 in (106.5 mm) | 3.94 in (100 mm) |
Head Diameter | 0.91in (23 mm) | 0.91in (23 mm) |
Body Diameter | 0.91in (23 mm) | 0.91in (23 mm) |
Packaging | Carton Box | Carton Box |
Use | Tactical, Everyday carry, Defensive, etc | Everyday Carry, Key-chain, Car, Camping, Fishing, Household, EDC, General use |
Reviews For S2R BARON II
>>This has been my go to torch since I got it. The size and weight make it easy to carry. Great quality and for its size the brightness is fantastic with a adjustment level for every situation.
>>I bought one for my partner as the S1R Baton II was a little too small. These through a huge amount of light, have excellent run times with multiple modes and are very small in the pocket. Excellent all round torch.
>>I’ve been looking for small yet bright torch as I work as Truck Mechanic. Tried other brands but not satisfied, until I found this S2R Baton II. This torch is perfect in everything, I have not use all of my inspection lights since I got this torch. It stays in my pocket all the time. Thanks to Olight, the service was great!
>>First thing that impressed me was the Olight Store dispatched my order, not just same day but practically within the hour. The torch itself is even more impressive. it feels solid like it's built to last, yet comfortable in the hand and the texture provides good grip. I like the soft beam profile which provides a nice even spread. This is an easy to use, easy to carry, powerful little torch. Very happy with my purchase.
>>Ok if you read my First Impressions of the S1R Baton ii you can pretty Much skip most of this as the S2R Baton ii is in essence just a bigger, brighter and longer lasting version of that miniature masterpiece.
The S2R Baton ii is an 18650 Every Day Carry torch. All day every day, it’s not a tactical torch by any standards, it’s not something you weapon mount, it has no crenulated bezel or rear tail switch.
This is a powerful, slender and sleek looking torch that pushes the limits of just how small an 18650 torch can be. Perfectly suited to typical every day torch needs; the TIR lens is not a thrower nor is it a dedicated flood light, it provides the perfect balance of the two while saving valuable real-estate typically taken up by a traditional reflector.
At just under 100 grams, 100mm long and 23mm max diameter you can drop this in to a pocket and forget it was ever there. Throw in MCCv2 magnetic charging, magnetic base and a bi-directional pocket clip, 1150 lumens (4,600cd) and the included 3200mAh battery this is a perfect EDC torch that has lived in my pocket by day and on my bed side table at night since I first got my grubby mitts on it.
The brightness levels are perfect for my needs (0.5lm Moonlight, 15lm low, 120lm medium, 400lm on high and a turbo of 1150lm for 2 minutes at a time) and the beam profile is just what the doctor ordered.
Reviews For WARRIOR MINI
>>great torch and very versatile for my work
>>Veeeery impressed with the build quality and the light throw. I will never buy another brand because of the magnetic charger design is so good!
>>This packs a huge punch and is able to deliver it in a very small form factor, it essentially is a smaller version of the M2R Pro, similar output, style and features but more compact. The tail-switch is great for rapid deployment and the 18650 makes it small enough to pocket carry. Excellent light and my current EDC for work.
>>The finish of titanium makes an already outstanding light just that much better. Slightly more weight gives a premium feel and the titanium looks fantastic, if you can get one on the secondary market, I would highly recommend.
>>I got this on a whim. I got the baton pro and I really like it. But I thought I would get this one on sale to see what the hype was about and I'm happy to say its worth it. I find my self using the tail switch the most and moonlight mode too.
>>I've had six of these so far- two of the Eternal 2 Copper limited edition versions and the whole Titanium Seasons set. All of them have had next level attention to detail and are extremely bright for the size. The only drawback is that you need to remember to put it on lockout mode if you leave it in your pocket with keys or other metal objects. If you forget to do that it can turn on and get very hot very quickly! Overall my favourite EDC light so far- I highly recommend it!
