What is the difference between Perun and Perun 2, let us have a look!
| Perun | Perun 2 | |
| GENERAL DATA | ||
| Beam Distance | 120 | 166 |
| Max. Performance (lumens) | 2,000 | 2,500 |
| Charge type | Magnetic USB charge base | MCC3 Magnetic Charging Cable |
| Compatible Batteries | Customised 3500 mAh 18650 battery | Customized 4000mAh 21700 Battery (Included) |
| LIGHTING LEVELS | ||
| LEVEL 1 (lumens) | 2000 lumens then drop to 800 lumens | 2,500~800 |
| Run-time LEVEL 1 | 2.5m (~2h40m) | 2+175 minutes |
| LEVEL 2 (lumens) | 500 | 500 |
| Run-time LEVEL 2 | 4 hours | 270 minutes |
| LEVEL 3 (lumens) | 120 | 120 |
| Run-time LEVEL 3 | 15 hours | 18 hours |
| LEVEL 4 (lumens) | 30 | 30 |
| Run-time LEVEL 4 | 47.5 hours | 66 hours |
| LEVEL 5 (lumens) | 5 | 5 |
| Run-time LEVEL 5 | 10 days | 12.5 days |
| TECHNICAL CHARACTERISTICS | ||
| Waterproof | IPX8 | IPX8 |
| Weight (g / oz) | 120 / 4.23 | 161/ 5.68 |
| Length (mm / in) | 112 / 4.41 | 120.7/ 4.75 |
| Head Diameter (mm / in) | 26.0 / 1.02 | 28.6/ 1.13 |
| Body Diameter (mm / in) | 23.0 / 0.91 | 27/ 1.06 |
Customer Reviews for Perun
>>I have purchased this light when on special for kayaking as well as the comfortable head band.
For me the positive feel of knowing it's there is a plus but for some I can understand completely about the weight maybe the only improvement I can think of is having either a remote switch or something for a quick access to the different light settings that can be either be done via a remote or wireless or wired way but other than that small detail it is an amazing light with great quality and design.
>>Is nice and small for its light output, does have a bit of weight for its small size = weight being part of its heavy duty built/feel. Fits really firm on headband = headband feels well make. Only thing I find hard is knowing what brightness setting its on, + whatever brightness you turn torch off same brightness returns when turning back on.
Charging could not be any easier, magnetic charge cable near jumps on by itself =red charging , green fully charged.
Customer Reviews for Perun 2
>>The Perun 2 is such a versatile light. I use it for work and on the weekend for fishing. It has never let me down. Highly recommend getting one if you haven't already.
>>What a super bright and wide beamed headlamp. This torch is so useful as a headlamp and a torch. A little heavy when worn in the harness but still useable. I use the pocket clip more than the harness.
>>Amazing headlamp/torch. Super powerful and tough. So many uses in comparison to most other headlamps. Being able to remove to torch from the headlight allows me to use the torch in situations that other headlamps are useless.
