Quick Navigation
1Introduction to Olight Oclip Pro S
2The Power of Five: A Lighting System for Every Scenario
3Designed for Effortless Carry: The Mounting Revolution
In the world of Everyday Carry (EDC), gear evolves. We’ve moved past the era of simply carrying a light that just turns on and off. Today, we demand versatility, durability, and intelligence from the tools we trust. Enter the Olight Oclip Pro S—the latest innovation from Olight that redefines what a compact light can do.
Building on the success of the Oclip Pro lineup, the new "S" variant is not just an incremental update; it is a statement. It’s a testament to Olight’s commitment to packing maximum utility into minimum space. Whether you are a weekend warrior, a DIY enthusiast, a night fisherman, or just someone who wants the best tool for the job, the Oclip Pro S is designed to be the only light you need.
Let’s dive deep into what makes this tiny titan a must-have for your kit.
The headline feature of the Oclip Pro S is its 5-in-1 Lighting System. Gone are the days of carrying multiple specialized lights. This single device houses five distinct light sources, ready to deploy at a moment's notice.
- White Light (Up to 600 Lumens): At its core, it’s a powerful workhorse. With a maximum output of 600 lumens, the main white light can flood a room, light up a dark trail, or help you find a dropped screw under the couch. The beam is clean and practical, with modes ranging from a scorching Turbo down to a barely-there 1-lumen Moonlight mode that preserves your night vision for up to an astonishing 144 hours.
- Pure 365nm UV Light: This isn't just a gimmick; it's a professional-grade tool. The high-purity 365nm UV beam is the gold standard for fluorescence. Use it to verify currency, inspect for pet stains on the carpet, check UV-reactive gear, or identify minerals. It’s an inspector, a detective, and a cleaner all in one.
- RGB Lighting (Red, Green, Blue): This is where the Oclip Pro S transcends the typical flashlight. These colors aren't just for show; they serve critical functions:
- Red Light: Essential for preserving night vision during astronomy sessions, late-night reading in a tent, or tactical applications. It’s also less likely to attract insects.
- Green Light: Often easier on the eyes for map reading and can provide better contrast in certain outdoor environments. It’s also a popular choice for fishing, as it doesn't spook fish as easily as white light.
- Blue Light: Ideal for tracking blood trails while hunting or adding a unique aesthetic for photography and mood lighting.
With multiple flashing modes for each color—including strobe, beacon, and blink—the Oclip Pro S also becomes a critical safety device for signaling in emergencies or marking your location in low-visibility conditions.
A light is only useful if you have it with you when you need it. The Oclip Pro S solves the "how do I carry this?" problem with an ingenious and versatile mounting system.
Weighing in at just 53 grams and measuring a pocket-friendly 57 x 28 x 27 mm, it disappears into your pocket. But its true genius lies in how it attaches to the world around you.
- The Spring-Loaded Clip: The heart of the system is a robust clip, rigorously tested to withstand 10,000 open-and-close cycles. It can securely attach to objects up to 14mm thick—think cap visors, backpack straps, MOLLE webbing, or even a thick book.
- Magnetic Might: Embedded in the body is a powerful magnet that allows for instant, hands-free mounting to any ferrous metal surface. Stick it to a car hood while you work on the engine, a file cabinet in the office, or a metal pipe in the basement.
- Hang It Up: The design also allows you to hang the light from a hook, a branch, or a nail, acting as a temporary lantern.
For true hands-free operation, the Oclip Pro S is also compatible with an optional headband (sold separately), transforming it into a lightweight headlamp perfect for running, hiking, or detailed work.
Built to Last, Ready for Anything
Olight products are known for their durability, and the Oclip Pro S is no exception. The body is machined from aerospace-grade 6061 Aluminum Alloy, ensuring it can handle drops and bumps without weighing you down.
To protect the critical optics, Olight has engineered a patented hinged dust cover rated for 3,000 open-close cycles. This keeps the lenses safe from scratches and debris when the light is not in use. Combine that with an IPX6 water resistance rating, and you have a companion that laughs in the face of rain, splashes, and accidental dunks.
Powering this tiny powerhouse is a 580mAh rechargeable Li-ion battery. When you do run low, the convenience of USB-C charging means you can top it up from your laptop, power bank, or car charger—no proprietary cables required.
Specifications at a Glance
| Parameter | Details |
| Dimensions | 57 x 28.05 x 27.83 mm (2.24" x 1.10" x 1.10") |
| Weight | 53 g / 1.87 oz (Including Battery) |
| Body Material | 6061 Aluminum Alloy |
| Battery | 580mAh Rechargeable Li-ion (USB-C) |
| Max Output | 600 Lumens |
| Waterproof Rating | IPX6 |
| UV Wavelength | 365-370nm |
Who Is the Oclip Pro S For?
- The Outdoor Enthusiast: From camping and hiking to fishing and hunting, the RGB modes and durable clip make it indispensable.
- The DIYer/Technician: Clip it to your pocket for a hands-free work light, or magnet it to a metal surface to illuminate your workspace.
- The Urban EDCer: A sleek, powerful, and versatile tool that clips perfectly to a bag or belt loop.
- The Preparedness Pro: A reliable backup light with long runtime and signaling capabilities that every emergency kit should have.
Final Verdict: Small Light, Infinite Possibilities
The Olight Oclip Pro S is more than just a flashlight; it's a lighting ecosystem. It understands that the modern user needs a tool that adapts to their environment, not the other way around. With its robust build, ingenious clip system, and game-changing 5-in-1 lighting, it sets a new standard for compact EDC lights.
Whether you need to illuminate a dark trail, inspect a valuable document, or signal for help, the Oclip Pro S is ready. It’s the one clip that rules them all.
Ready to upgrade your carry game? Head over to grab your Oclip Pro S and experience the light of infinite possibilities.
