It has been a few days since we launched our new product "Obulb Pro". We received some feedback from our clients. What's the difference between Obulb Pro and Obulb MC? Do Obulb Pro and Obulb MC have different features? They want to figure it out. In order to introduce the differences between these two series, I am going to make a comparison. So let's get started.
Following is a table that illustrates how Obulb Pro and Obulb MC differ in general. We can see from this tale that Obulb Pro has some differences and similarities with Obulb MC. We'll find out one by one.
1. Maximum Illumination
Obulb Pro is significantly brighter than Obulb MC, as shown in this table. Also, Obulb Pro has a longer run time. It can continue working for up to 84 hours. Therefore, it can be used on a daily basis to meet your needs.
2. Bluetooth APP Control
Compared with Obulb MC, Obulb Pro is a Bluetooth-controlled led bulb light with the most outstanding feature being that it can be controlled by the Olight APP. On the Olight App, users can change the device's brightness, color, modes, and runtime effortlessly, as well as check the remaining battery power. Additionally, the Olight APP allows you to share data and control groups. The OR Code can also be scanned by your friends and relatives, allowing you to control multiple Obulb Pro-led bulbs simultaneously.
3. Mode & Color
A total of 8 lighting modes are available with Obulb MC. They are warm white light, red/green/blue/ flashing red light, 256-color gradient change, and 7-color cycling.
With Obulb Pro, you will get warm white light, red/green/blue light, red flash, cycle between 7 colors, and fade between 7 colors. Soft rubber-coated buttons make it easy to switch between illumination, ambient light, and decoration modes. There are 7 light modes on this magnetic light orb, and you can control it by an app.
4. Battery Capacity
Powered by a 630mAh rechargeable battery, Obulb MC lasts for up to 40 hours. The built-in 1650mAh battery allows the Obulb Pro to run continuously for 84 hours. it can be fully charged in 3 hours.
5. Weight & Size
The Obulb MC is only 2.13 inches in diameter and weighs only 2.05 ounces/58 grams. With the adhesive metal badge and its magnetic bottom, you can attach it to any part of your home you like. The Obulb Pro is bigger and more functional than Obulb and Obulb MC, but still compact enough to carry by hand or in a backpack.
6. Package Contents
