VIP Early Access: Available at 20:00 21/3 —— 20:00 24/3 (AEDT)
Normal Sale: Available at 20:00 24/3 —— 23:59 25/3 (AEDT)
Harvesting comes to one and all when the Autumn Equinox does fall. Get into March Flash Sale now!
FREE GIFT
1. FREE I3E EOS OD Green will be automatically added to your cart for your first logging in.
2. Gift Activities:
Customers purchasing Olight Headlamps Pack
Olight Headlamps Pack includes: Perun 2 Clover Gradient、H05 Lite Blue&Pink、Perun Mini Kit
LIMITED TIME EDITION
1. Olight Perun 2 Clover Gradient <200 Limited>
✦ Max 2,500-lumen with a 166-meter throw
✦ Passed 1.5-metre drop test and IPX8 waterproof
✦ Dual-purpose use as a headlamp or handheld light
2. Olight Perun 2 Clover Gradient+I1R 2 PRO Dark Red/Swivel Blue <SAVE $ 61.21 >
3. Swivel - Magnetic Work light + USB Charger Blue or Moss Green
✦COB module that produces ample near-field floodlight when repairing things or working
✦Extra LED at its head to deliver a focused beam just like an EDC flashlight.
✦180° adjustable clip-style stand allows you to adjust the beam angle as needed, and hang the product on a backpack, tent, branch, or more.
✦Built-in 2600mAh battery that is rechargeable via a Type-C port, achieving a max runtime of 90 hours when using the energy-saving low mode.
4. Olight Headlamp H05 Lite-Blue or Pink
5. Olight H05 Lite-Blue+H05 Lite-Pink Bundle <SAVE$ 21.97 >
✦Eye-safe Beam: With an anti-glare lens, it protects your eyesight while being used in dark environments.
✦Fashionable Appearance:The stylish appearance is full of vigor and vitality, allowing you to choose between blue and pink for the family.
✦Easy Operation:The large top button makes it super easy to switch between white light, red light, and other settings as well.
✦45° Adjustable:The headlamp can be tilted up to 45 degrees to satisfy any viewing angle you may have.
6.Olight Perun 2 Black +I3T Plus Black / Open Mini Blue Bundle< SAVE $ 51.27 >
I3T PLUS BLACK
✦Useful Light Source:It delivers a high output of 250 lumens and a low output of 15 lumens, perfect for taking care of everyday tasks.
✦Extended Runtime: Powered by two widely available AAA batteries, it runs up to 28 hours at 15 lumens.
OPEN MINI BLUE
✦Strong and Stylish: The aluminum alloy body is tough and wear-resistant. It comes with finely machined hollow rifling grooves for a dynamic and stylish look.
✦Small and Concealed: Only 3.66 inches in length, it can be totally concealed in your shirt pocket.
1. Seeker 3 Pro 4200 Lumens Flashlight-Forest Gradient/Black
●High Performance: 4 high-performance LEDs for an amazingly bright 4,200 lumens, 31% higher than the Seeker 2 Pro
●Smart Proximity Sensor: Built-in thermal and proximity sensors to ensure maximum safety in case of overheating or lens obstructions
●Powerful & Rechargeable:A large-capacity customized 5000mAh rechargeable battery, ensuring a max runtime of 15 days
2. i1R 2 PRO EOS 180 Lumens USB Charging Keyring Light-Dark Red/Black/Blue
● Higher performance: The CSP LED paired with a TIR optic lens, generates a max output of 180 lumens, 48m, 20% higher than i1R 2.
●New charging type: Adopts the new USB-C port instead of the old Micro-USB port, which makes charging easier. Built-in 130mAh Lithium-ion battery, makes the light runs up to 12 hours. SAVE $ 9
3. Seeker 3 Pro Forest Gradient+H05 Lite-Blue/H05 Lite-Pink/I1R2 Pro Dark Red Bundle
4. Array 2 Max 600 lumens Headlamp
✦Aim the light precisely with the 60-degree adjustable design
✦The whole product weighs only 109g/3.84oz
✦Passed 1.0-metre drop test and IPX4 waterproof
5 .Array 2S 1,000 Lumens USB Rechargeable LED Headlamp Black or Orange
✦Max 1,000 lumens with a runtime up to 30 hours, IPX4 Water-resistant
✦Use the side switch or simply wave your hand in front of the head
✦The light can be tilted precisely 60 degrees to satisfy any angle you need
6. Opry
Paired with a small clip, easy to hang on your bag or clothes, perfect for outdoor adventure, hiking, camping, etc.
