Q1: What is the reason when rotating the switch, the battery indicator lights up but the Marauder Mini flashlight cannot be turned on?
A: The rotary switch needs to be rotated 90 degrees or more before pressing the button to turn on the flashlight.
Q2: Can the Marauder Mini flashlight be charged using MCC1A/omino?
A: It can be charged using MCC1A, but the charging speed may be slower, and the indicator light on the charger may flicker. It can also be charged using Omino.
Q3: What could be the issue if the Marauder Mini flashlight cannot enter the L7 brightness mode?
A: The problem could be due to low battery voltage.
Q4: What could be the reasons for the Marauder Mini flashlight not entering the L4 mode or higher modes?
A: 1. Insufficient battery power;
2. Extremely low ambient temperature (below 2 degrees Celsius).
Q5: Why is the Marauder Mini flashlight charging slowly?
A: Please use the provided MCC3 cable and a fast-charging adapter for optimal charging speed.
Q6: Does the Marauder Mini have a proximity sensor?
A: It has temperature control but does not have light-sensing capabilities.
Q7: How long does it take to charge the Marauder Mini?
A: The charging time for the Marauder Mini can vary depending on the specific charger and charging conditions used. However, typically, it takes around 4-5 hours to fully charge the Marauder Mini flashlight.
