The javelot Pro 2 has an ultra-throw and intense beam, best for hunting light, search, spotlighting, and rescue. It is an ultra bright long-distance thrower that can be used handheld or a WML. Four brightness levels, rechargeable, and gives an unparalleled output of up to 2,500 lumens with a 1050 beam distance.
Features
Ultimate long throw flashlight
This best hunting torch Australia can be your go to long throw flashlight for rescue and handheld search or platform mounted hunting. Upgraded to a remarkable 2500 lumen cool white targeted beam that reaches up to 1148 yards, that is more than 11 football fields. The durable aluminum alloy construction as well as IPX8 waterproof rating makes this product a perfect outdoor long throw torch.
Impressive battery life
The Javelot Pro 2 has been packed with a removable battery pack that comprises 2 5000mAh 21700 for extended runtimes up to twelve days on a single charge. Why take it out, when you can just use the magnetic charging cable from Olight to snap onto the tailcap for quick 2A charging. The quad LED battery level indicator by the side switch gives quick and intuitive readout.
Great for mounted, or handheld
The Javelot pro 2 features silent dual-switches. Use the tactical tail switch to directly access the low and turbo mode and the side switch to cycle all 4 brightness settings. The slim handle gives a stable balance point for mounting or anything from scopes to barrels while the deep knurling pattern gives best grip for handheld use.
Advantages
Long range flashlight
Give the power of up to 2500 lumens with a very long range of 1050 meters.
Dual switches
A side switch to pick four different modes during daily use and dual stage tail switch for tactical work.
Visualized indicators
Four level brightness and battery level indicators around the side switch that can be quick at glance.
Optional accessories
With the latest optional two button remote switch, you can straight access the low and turbo output.
Technical specifications
· LEDs: High performance cool white LED
· Power: Rechargeable battery 21700 x 2 (3.6V 5000mAh)
· Bezel diameter: 248in/63mm
· Body diameter: 1.02in/26mm
· Length: 10’’
· Weight: 423g
Uses of Javelot Pro 2 hunting light
Striking tool
Some self-defense tactical lights can work as striking tools if all come to it. For example, a crenelated bezel has been featured with a jagged edge that protrudes from the face rim and around the lens. If used to strike soft tissue, it can produce a gaping wound. This feature can be so successful if you hit the attacker on the forehead. When blood dips down to the eyes can affect the attacker’s vision.
The Signalling device
Another advantage of having a self-defense tactical light is that it can be used for help signal. Light travels longer and faster than sound, and this is a physical fact. So, when you are having issues, you can use it to signal for help.
Some defense instructors advise using the torch and then turning it off and move to another location.
Illumination
One of the advantages of having a self-defense light is that you can use it to better your vision in many conditions that need light. For example, if you are in a survival condition, you can better your odds by using the hunting torch.
Bear in mind that if any person wants to attack you, you need to see the type of weapon they have. If you were driving and your vehicle breaks down, you can use the torch illumination to seek help.
End words
Featuring a highest beam distance of 1,050 and a maximum brightness of 2,500 lumens, the Javelot Pro 2 is at home hand or mounted on a barrel or scope, it is a versatile hunting light with a 10,000 mAh battery pack and super simple magnetic charging, four level battery and brightness level indicators around the side switch make the light can be read clearly at a single glance. This product also supports the dual-button remote switch; it can access low or turbo output directly without breaking your grip. Use an optional green/red filter to decrease the visual disturbance of night hunting.
