The evolution of Everyday Carry (EDC) lighting reaches a new peak in 2026 with the introduction of specialized multi-functional tools. The Oclip series represents a strategic shift from traditional handheld torches to versatile, wearable illumination. This comprehensive review examines the Olight Oclip Pro S and its sibling, the Oclip Pro, to help you determine which model best fits your tactical, professional, and outdoor requirements.
- Brief overview of Oclip Pro and Oclip Pro S
- Oclip Pro vs Oclip Pro S: Quick Comparison
- Who Should Choose Oclip Pro?
- Who Should Choose Oclip Pro S?
- Use Case Comparison: Which Model Fits Your Lifestyle?
- Price vs Value: Which One Is Worth It?
- Final Verdict: Which One Should You Choose?
The Oclip Pro and Oclip Pro S represent the premium tier of Olight’s clip-on lighting solutions. These are not merely backup lights; they are high-performance tools housed in durable 6061 aluminum alloy. The Oclip Pro is engineered for users requiring precise beam control, featuring a dedicated spotlight for long-distance visibility and a floodlight for wide-area tasks.
In contrast, the Oclip Pro S is a specialized multi-spectrum device. It trades the dual-beam focus of the Pro for a high-output white light combined with Red, Green, Blue (RGB), and Ultraviolet (UV) sources. Both devices utilize modern USB-C charging and a built-in 580mAh battery, maintaining a lightweight profile of only 53 grams for effortless carry.
Understanding the technical divergence between these two models is essential for selecting the right tool for your specific environment.
Key Specs Overview
| Feature | Oclip Pro | Oclip Pro S |
| Max Output | 500 Lumens | 600 Lumens |
| Max Throw | 120 Meters (393 ft) | 80 Meters (262 ft) |
| Light Source | Flood, Spot, Red | White, Red, Green, Blue, UV |
| Max Intensity | 3,600 Candela | 1,600 Candela |
| Battery | 580mAh Li-ion | 580mAh Li-ion |
| Charging | USB-C | USB-C |
| Weight | 53g | 53g |
| Body Material | Aluminum Alloy | 6061 Aluminum Alloy |
Major Differences at a Glance
The primary difference lies in the optical lens configuration. The Oclip Pro features a dual-lens setup that allows it to project a concentrated beam up to 120 meters, effectively serving as a miniature searchlight for distance identification.
The Oclip Pro S utilizes its internal architecture to house five distinct LED types. While it reaches a higher peak brightness of 600 lumens, it distributes that light more broadly, resulting in a shorter 80-meter throw. The inclusion of UV (365-370nm) and RGB LEDs transforms the Pro S into a versatile multi-tool for inspection and signaling.
Best for Budget-Conscious Users
The Oclip Pro is the go-to choice for those focusing on traditional lighting utility. If your primary need is a reliable white light that can punch through the dark across a parking lot or down a hiking trail, the Pro model offers superior value in terms of distance and clarity per dollar.
Recommended for First-Time Buyers
For those new to premium EDC gear, the Oclip Pro provides a simplified user interface. Managing a spotlight and floodlight covers 95% of daily needs, making it a practical entry point into the Olight ecosystem without the complexity of multi-color modes.
Best for Power Users
The Oclip Pro S is designed for enthusiasts who demand maximum functionality from every gram of gear. Having UV and RGB capability in a 53g package eliminates the need for separate specialized lights. It’s perfect for those who want to switch from high-output white light to 365nm UV for instant inspection.
Ideal for Outdoor & Professional Use
Professionals and tactical users benefit from specific wavelengths:
- UV Light: Essential for fluid detection, HVAC leaks, and currency/document verification.
- Red/Green/Blue: Preserves night vision (Red), high-contrast map reading (Green), or tactical tracking (Blue).
- RGB Signaling: Vital for non-verbal group communication in outdoor or emergency settings.
Daily Commuting & Office Use
For the urban commuter, the Oclip Pro is typically superior. The spotlight feature provides early warning of obstacles when walking in poorly lit urban areas. The floodlight is ideal for searching bags or lighting up a workspace during a power outage.
Travel & Outdoor Activities
The Oclip Pro S shines in travel. In hotels, the UV light acts as a hygiene inspector. For hikers, the Red light prevents "blinding" campmates, while the Green light offers better contrast for topo maps without attracting insects like white light does.
Industrial & Rescue Scenarios
In industrial environments, the Oclip Pro S UV light helps find fluorescent dyes in engine leaks. However, if the job requires spotting markers at a significant distance, the Oclip Pro’s 3,600-candela intensity remains the more effective tool.
While prices vary based on regional Australian promotions, the Oclip Pro S generally commands a higher price. This reflects the increased complexity of the 5-in-1 LED array.
Value Summary:
- The Minimalist: Oclip Pro offers the best "Lumen-per-Dollar" for pure illumination.
- The Specialist: Oclip Pro S is a cost-effective 5-in-1 tool, replacing multiple dedicated lights.
The decision rests on Reach vs. Versatility.
- Choose Oclip Pro if: You need a clip-on light that performs like a traditional flashlight with maximum throw (120m) and a simple interface.
- Choose Oclip Pro S if: You need a tactical multi-tool. If UV inspection or RGB signaling is part of your professional or outdoor routine, this is the most advanced EDC clip light in 2026.
What is the main difference between Oclip Pro and Pro S?
The Oclip Pro focuses on beam distance (Spot/Flood, 120m). The Oclip Pro S focuses on versatility, offering White, Red, Green, Blue, and UV LEDs for specialized tasks.
Is the clip strong enough for running?
Yes, both models utilize a high-tension spring clip designed for secure attachment to hat brims, straps, or pockets. At just 53g, they offer stable, bounce-free performance during active movement.
Which one is better for beginners?
The Oclip Pro is generally better for beginners due to its more straightforward interface and focus on standard white-light applications.
