The Obulb family has seen numerous additions that share similarities, but also have their unique features. Its latest and most impressive addition is the Obulb Plus. This smart lighting device can serve several purposes, from being a bright flashlight or providing ambient light to your room to being a fun party trick or decoration. Don't miss the chance to try out this exciting new addition to the world of smart lighting!
The Obulb Plus is a multicolor, rechargeable, and magnetic light orb featuring a touch switch and app control. With a 3.15-inch diameter, it is bigger than the Obulb Pro, illuminating a larger area. The Obulb Pro S is the updated version of Obulb Pro. Even though it is the same size as the Obulb Pro, it adds more colorful modes and more interesting functions.
In this article, we will be discussing the differences between three popular portable lights: the Obulb Plus, the Obulb Pro S, and the Obulb Pro. While all of these lights share some similarities, such as their compact size and rechargeable batteries, there are also some key differences that set them apart.
The differences among Obulb Plus & Obulb Pro S & Obulb Pro
Size
Obulb Plus: 2.90*3.15in. Larger Size, It illuminates a larger area and feels even better in your hands. The Obulb Plus outshines the Obulb Pro S in terms of size, with a diameter of 3.15 inches, making it capable of illuminating a larger area. Its brightness level of 300 lumens is impressive and will surely satisfy your lighting needs. It's an essential addition to your collection.
Obulb Pro S: 2.56*2.28in. Even though it is the same size as the Obulb Pro with a 2.56-inch diameter, it adds more colorful modes and more interesting functions.
Obulb Pro: 2.56*2.28in. It's compact enough to be carried by hand or in a backpack.
Max. output
Obulb Plus : 300 Lumens. It delivers up to 300 lumens and a max runtime of 49 hours, great for illumination, ambient light or decoration.
Obulb Pro S : 240 lumens. It produces a maximum output of 240 lumens, making it a reliable source of illumination in a variety of settings.
Obulb Pro : 240 lumens.
Max.Runtime
Obulb Plus: The built-in 2000mAh battery allows up to 49 hours of continuous lighting, which saves users the bother of frequent charging.
Obulb Pro S: The built-in 1650mAh battery allows up to 6.5 days of use, which satisfies the requirement of almost one week of lighting.
Obulb Pro: The built-in 1650mAh battery allows up to 84 hours of runtime.
APP Controlled
Obulb Plus: can be controlled by the Olight Hub via Bluetooth.
Obulb Pro S: can be controlled by the Olight Hub via Bluetooth.
Obulb Pro: can be controlled by the OLIGHT APP via Bluetooth.
What's the difference between these two apps ( Olight Hub and OLIGHT)?
Olight Hub: With this APP, users can change its mode, brightness, and color, and check the remaining power. More functions are also available, such as group control, music rhythm, whack-a-mole, countdown, etc.
OLIGHT: With this APP, users can change its mode, brightness, and color, and check the remaining power and runtime. The APP also enables group control and data sharing.
Operation lighting modes
Obulb Plus: A total of 21 color light modes are available.
Obulb Pro S: A total of 12 color light modes are optional.
Obulb Pro: Warm white light, red/green/blue light, red flash, fade between 7 colors, cycle between 7 colors.
Effects of the ambient light modes
Obulb Plus: uses 75 full-color lamp beads with a three-dimensional layout, resulting in more delicate and rich colors. The new ambient firelight special effect is comfortable with various modes such as flame mode and fireworks mode. Additionally, there is a large space for expanding light modes and sustainable remote upgrades to enhance the lighting effects.
Obulb Pro S: only has 8 dazzling lamp beads with limited lighting effects and a smaller space for expanding light modes.
Obulb Pro: uses ordinary RGB light beads, which have a relatively limited range of color modes.
Operation mode
Obulb Plus: adopts a touch switch on its top, with which you can easily choose from 7 modes manually, and it also features step-less dimming by pressing and holding the switch.
Obulb Pro S: One button switch, the switch position is at the bottom, maintaining the operation method of the old Obulb Series
Obulb Pro: One button switch. Single click the rubber-coated button to switch on the Obulb Pro and cycle through 7 light modes, or long-press to turn it off.
Supporting magnets
Obulb Plus: Using a new magnetic attraction piece, the magnetic force is stronger and the adsorption is firmer.
Obulb Pro S: Use the normal magnet
Obulb Pro: Use the normal magnet
The similarities among Obulb Plus & Obulb Pro S & Obulb Pro
One Step Charging
With this MCC3 cable, the devices can be fully charged in just 3 hours, making it a quick and easy process compared to traditional charging methods. It is particularly useful for individuals who need to use their devices frequently and require them to be charged quickly. Overall, the one-step charging feature with the magnetic charging cable is a convenient and efficient way to ensure that your devices are always powered up and ready for use.
Magnetic bottom
they all have a magnetic base and include an adhesive metal badge for easy attachment to smooth surfaces. When you attach the metal badge to the smooth surface, it will be attracted to the magnetic base and stay securely in place.
Additionally, the ease of attachment and removal offered by the magnetic base and adhesive badge means that you can easily move the attached item as needed without leaving residue or damaging the surface to which it was attached.
Sturdy Build
They are all certified to be IPX7 waterproof, ensuring that they can resist water damage when submerged up to one meter. Additionally, they are also designed to be 1-meter impact-resistant, meaning that they can handle bumps, drops, and impacts without being damaged.
Group Control
you can control a group of the Oblub Plus/Obulb Pro S/Obulb Pro at the same time with a simple tap.This implies that you can manage these devices simultaneously, without having to individually adjust each one.
This feature could prove to be extremely useful for users, especially if they are looking to create a unified lighting environment or ambiance. Additionally, controlling these devices through a single tap could save users a significant amount of time and effort, making it an extremely convenient feature for those who use these devices regularly.
We have introduced the Obulb Plus and Obulb Pro S recently, which provide versatile and convenient lighting solutions. Both lights are packed with features, such as magnetic attachment, app control, and a sturdy build, making them ideal for various situations.
While the Obulb Plus is larger and brighter, has more color-light modes, and has a more intelligent system, the Obulb Pro S is more portable and compact. Depending on the user's preferences, they can select either of these lights suitable for their specific needs, such as ambient lighting, decoration, or on-the-go use. With their exceptional functionality and trustworthy performance, the Obulb Plus and Obulb Pro S are excellent choices for a top-notch night light.
