What is the function of the pressure switch?
For weapon lights, indispensable accessories like flashlight remote and pressure switches are crucial, especially for first responders, security personnel, military operatives, and law enforcement officers who require efficient management of their flashlights.
Integration of pressure switches enables swift and responsive activation of flashlights, improving functionality while minimizing continuous operation. These accessories not only reduce operational noise but also facilitate a natural grip on the weapon, optimizing flashlight usage.
Furthermore, employing high-quality pressure and remote switches ensures that your tactical light is activated only when necessary, preventing premature battery drainage and imparting a professional aesthetic to your gear.
Selecting switches from reputable manufacturers is recommended to ensure top-notch performance and reliability.
Inner Workings of Flashlight Components with Remote Pressure Switch
Activating the flashlight switch initiates an electrical flow powered by the battery, creating a connection between two conductive strips.
The batteries' configuration allows for the flow of electricity between their positive and negative poles. A spring at the base links to a contact strip, establishing an electrical pathway to the lamp via another strip on the switch's opposite side.
Another element connected to the lamp links with the top battery's positive terminal, closing the circuit necessary for powering the lamp.
When activated, the lamp emits light through its LED or tungsten filament, which is then focused and projected as a steady beam by the surrounding reflector, visible as the torch's output. A protective clear lens shields the lamp from potential damage.
Turning off the flashlight switch interrupts the connection between the two strips, halting the electrical current flow and extinguishing the light, effectively deactivating the flashlight.
Buying Guide for Tactical Pressure Switches
Mounting Flexibility
A remote weapon light switch equipped with an integrated Picatinny clamp can be effortlessly mounted onto the rail system without requiring any alterations.
Reliability and Responsiveness
Given the potential for pressure switches to malfunction, it is recommended to have a secondary method of activation as a fail-safe measure.
Enhanced Compatibility for Modern High-Output Lights
To ensure optimal electrical contact, pressure switches for modern high-output lights should feature thicker wires.
Optimal Cord Length
Choosing the right cord length is crucial to maintaining a streamlined and snag-free setup.
Dual Operational Capabilities
Certain pressure switches are designed to operate two devices simultaneously, enabling separate control for the light and laser functions.
Olight Remote Pressure Switches Designed for Tactical Flashlights
1, Olight SROD Remote Pressure Switch
The SROD is a seven-inch remote pressure switch with a push-to-lock feature, offering high and low gear options. It conveniently attaches to compatible torches such as the Javelot Pro 2, Javelot, Warrior X 3, Warrior X 4, Warrior 3 and Warrior 3S, enabling hassle-free operation.
This remote pressure switch empowers users to achieve two key functions with their torch that would typically be inaccessible. Firstly, it enables swift access to the flashlight's low and high brightness output modes without the need to cycle through them, enhancing ease of use. Secondly, it facilitates the conversion of any of the three compatible torches into weapon-mounted lights, providing enhanced accessibility and versatility through its cable.
Key features include:
* Single-click activation for switching between high and low settings
* Magnetic locking mechanism with a seven-inch cable
* Silent, one-click activation of the light
2, ROD-7 Magnetic Remote Pressure Switch
Effortlessly operate your Olight Warrior X Turbo flashlight using the ROD-7 remote pressure switch, eliminating the need to reposition your hand. This switch serves as a convenient spare or replacement for the Odin and is fully compatible with the Warrior X Turbo. It securely attaches to the light's tail magnetically, without requiring removal of the tail cap switch, providing a seamless locking mechanism. The switch is positioned within a flexible bracket that easily snaps onto a Picatinny rail, allowing you to position it conveniently within reach.
* Push-to-lock functionality and magnetic attachment
* Primarily designed for the Warrior X Turbo, Javelot Turbo, Odin, Odin Turbo, Odin Mini.
3, RWX07 Magnetic Remote Pressure Switch
The RWX-07 remote pressure switch, featuring magnetic attachment is a pioneering feature in the global market. This switch facilitates swift tactical lighting maneuvers and is compatible with Warrior X, Warrior X Pro, Javelot Pro, M2R, M2R Pro. Experience reduced cord clutter and quieter clicks, allowing for focused performance during critical moments. Elevate your tactical proficiency and lighting efficiency with this advanced switch.
* Minimal click noise for enhanced concentration
* Effortless and rapid attachment process
* Exceptionally low standby current consumption
* Reduced risk of tangling, cord damage, and snags
* Extended electronic switch lifespan for prolonged usage reliability.
4, RPL-7 Magnetic Remote Pressure Switch
The Olight RP-7 stands out as a magnetic remote force switch crafted specifically for the Olight PL Pro flashlight model. Featuring a responsive and silent pad, it incorporates a lengthy elastic contact strip, enabling activation from any point while maintaining user concealment. The RP-7 seamlessly attaches to the flashlight via magnetic connection, ensuring effortless attachment and detachment as needed. Enhance your Olight PL Pro for rifle applications by integrating the RPL-7 pressure switch.
* Silent operation and extended rifle force pad
* Magnetic linking capability with the flashlight
* Compatibility with Baldr Pro R flashlight model.
5, Olight M2R Magnetic Remote Pressure Switch
This remote switch is designed for Olight's M2R Warrior torch. Swap out the tailcap with this accessory to effortlessly activate the light while mounted on a firearm.
Please note that this pressure switch is not suitable for use with the M2R Pro model.
Key Features:
Equipped with a quiet, durable electronic switch for prolonged use.
The coiled cable extension offers flexibility, extending from 25cm to 80cm.
Boasts an exceptionally low standby current for efficiency.
* Specifications:
* Coiled Cable Length: 249.94 mm
* Fully Stretched Cable Length: 500.12 mm
* Switch Pad Size: 42.92 mm
* Weight: 40g
6, Olight RWX Magnetic Remote Pressure Switch
Our pressure switch tailored specifically for the Warrior X, Javelot Pro, and M2R Pro flashlights, featuring a whisper-quiet operation and a responsive pad for seamless switch control.
With a coiled cable extending up to 0.8 meters, the RWX offers extended reach for optimal functionality. Unique to the industry, it securely attaches to the flashlight body magnetically, setting a new standard. The switch pad boasts a generously sized elastic strip, ensuring effortless activation across its entire surface.
The RWX serves as the ideal accessory for your Warrior X, Javelot Pro, or M2R Pro flashlight.
Notable Features:
* Coiled cable naturally measures 0.25 meters, stretching to 0.8 meters when fully extended.
* Magnetic attachment ensures a secure connection to the flashlight body.
* Silent switch operation to maintain user discretion.
* Enhanced switch pad design for convenient and versatile activation.
* Weight: 45g / 1.56 oz
* Material: AL6061-T6 Aluminum Alloy & Heatshrink Tubing
7, Olight SRPL-7 Remote Pressure Switch for PL-3R
Crafted with precision and compatibility in mind, the SRPL-7 offers seamless integration with the PL-3R model, ensuring optimal performance in various scenarios.
Whether you're navigating through challenging environments or engaging in tactical operations, the SRPL-7 provides reliable control and versatility, empowering you to adapt to dynamic situations with ease. Elevate your lighting experience and maximize the potential of your PL-3R flashlight with the SRPL-7 Remote Pressure Switch.
8, Olight ROD Remote Pressure Switch for Javelot Turbo & Warrior X Turbo
The ROD Remote Pressure Switch is specifically designed to provide convenient and efficient remote activation for the Javelot Turbo and Warrior X Turbo flashlights.
Whether in low-light environments, tactical operations, or outdoor activities, the ROD Remote Pressure Switch enhances the functionality and adaptability of the Javelot Turbo and Warrior X Turbo flashlights, ensuring quick and easy access to reliable lighting when it matters most.
