As one of Olight’s best sellers, Seeker Series definitely deserves a lot more attention than it currently does.
Be it applied in the household, outdoor, or law enforcement fields, Seeker Series won’t disappoint anyone.
Until now, this series has two members: Seeker 2 & Seeker 2 Pro.
We will start with a brief introduction on these two members.
Basic Introduction
Seeker 2
Simply Powerful
Powered by a single 21700 (5000 mAh) customized lithium rechargeable battery, the Seeker 2 delivers a maximum output of 3,000 lumens. Using three highly efficient OSRAM LEDs paired with a TIR optic lens help to provide a perfect medium and close-range illumination experience.
The Seeker 2 also features a large side switch, located near the head of the light, for comfortable thumb operation. The indicator built into the center of the switch clearly displays the remaining battery power with a green, orange or red color. The contoured grooves on the surface of the aluminum alloy body is designed to provide a comfortable non-slip grip.
Compatible with most USB power sources, the magnetic charging cable is convenient to use, making the Seeker 2 a perfect illumination tool to be used at home, outdoors, or on duty.
Seeker 2 Pro
L-dock Charging, On-the-go LED Flashlight
The Seeker 2 pro is a powerful, rechargeable side-switch LED flashlight. Powered by a single, maximum capacity, (5000mAh) 21700 customized lithium rechargeable battery, that helps this light deliver a maximum output of 3200 lumens. It uses high-quality LEDs paired with a TIR optic lens, providing a perfect medium and close-range illumination experience.
The Seeker 2 pro also features a large side switch located near the head of the light for comfortable thumb operation and indicators on both sides of the switch clearly display the battery power and brightness level. With milled finger grooves and dermatoglyphic silicone, the Seeker 2 pro is ergonomically designed to be extremely comfortable and provides a non-slip grip.
The Seeker 2 pro includes a 3.9 ft long 1A magnetic USB cable (The MCC1AL is compatible with OLIGHT S, M, and H series). The provided L-dock can be attached to or fixed on a wall close to a power source for quick and easy access. Compatible with most USB power sources, the magnetic charging cable is convenient to use, making it an ideal illumination kit to be used at home, outdoors, or while on duty.
Then a detailed comparison between Seeker 2 and Seeker 2 Pro to show their pros and cons in technical terms.
| General Data | Seeker 2 | Seeker 2 Pro |
| Max Performance(lumens) | 3000 | 3200 |
| Beam Distance(ft/m) | 721/220 | 820/250 |
| Light Intensity(candela) | 12100 | 15600 |
| Form/Size Factor | Large Size(Deodorant Spray/Coke Can) | Large Size(Deodorant Spray/Coke Can) |
| Series | Series Seeker(Rechargeable) | Series Seeker(Rechargeable) |
| Lens/Reflector Type | Smooth Reflector(Central Area and Flood Area) | Smooth Reflector(Central Area and Flood Area) |
| Charge Type | Magnetic USB Charging Cable | Magnetic Charging Cable |
| Compatible Batteries | Customized 21700 5000mAh | Customized 21700 5000mAh |
| Lighting Levels | Seeker 2 | Seeker 2 Pro |
| Level 1 | 3000—600 lumens/3+155 mins | 3200—600 lumens/2+150 mins |
| Level 2 | 1200—600 lumens/110+50 mins | 1200—600 lumens/110+30 mins |
| Level 3 | 300 lumens/13 hours | 300 lumen/9.7 hours |
| Level 4 | 50 lumens/72 hours | 50 lumens/50 hours |
| Level 5 | 5 lumens/15 days | 5 lumens/12 days |
| Strobe | Yes | Yes |
| SOS/Beacon | No | No |
| Technical Characteristics | Seeker 2 | Seeker 2 Pro |
| Waterproof | IPX8 | IPX8 |
| Weight(g/oz) | 185/6.53 | 198/6.98 |
| Length(mm/in) | 126/4.96 | 128/5.04 |
| Head Diameter(mm/in) | 35/1.38 | 35/1.38 |
| Body Diameter(mm/in) | 27.5/1.08 | 28/1.1 |
| LED | OSRAM LED Cool White | XP-L LED |
| Packaging | Carton Gift Box | Carton Gift Box |
| Use | Search & Rescue, Camping, Industrial, Police, Security, Self Defence, Outdoor | Search & Rescue, Camping, Industrial, Police, Security, Self Defence, Outdoor |
| Package Contents | Seeker 2(Battery Included)✖1 0.5m MCC1A Magnetic Charging Cable✖1 Lanyard✖1 User Manual✖1 | Seeker 2 Pro(Battery Included)✖1 MCC1A Magnetic Charging Cable✖1 Self-adhesive Ply-yarn Drill✖2 L-dock Charging Kit✖1 Holster✖1 Cleaning Cloth✖1 User Manual✖1 |
Unique Characteristics of Seeker 2 Pro
As the upgraded version of Seeker 2, Seeker 2 Pro surely is superior in many ways.
1. More Colours & More Choices
Seeker 2 has only been designed in classic black and blue, while Seeker 2 Pro provides yet 5 more colours, including mint green, desert tan, orange, OD green, and carbon fiber.
Therefore, customers now possess a lot more freedom in their choice of colour matter. Providing more colours to be chosen from enables customer to pick
whatever colour they like.
2. User-friendly Design
Except for the obviously improved max output and throw, Seeker 2 Pro’s real advantages actually lie in its capacity for providing a better user experience.
For charging, Seeker 2 Pro is equipped with a convenient L-dock which can be attached to or fixed (3M tape included) on a wall or table indoors that is close to a power source, thus providing a dedicated charging location.
For visual display indicators, Seeker 2 Pro has eight indicators in total: four on the right side to display the battery level, while the other four on the left side to display the brightness level. To learn about both the battery level and brightness level of your torch, one glimpse would be enough.
For texture, Seeker 2 Pro adopts milled finger grooves as well as dermatoglyphic silicone on the surface of the holding position, making it soft and anti-slip.
In a word, Seeker 2 Pro exceeds its predecessor not only in performance but also in user experience.
