Olantern Classic Mini Review
Elegance of the Past,
In a Lantern So Compact.
Overview
Introduction
What's in the box
Batteries and charging
Lighting modes
Led and Beam
Beamshots
Application
Comparison Of Olantern Classic Pro 2
Video
Introduction
The Olantern Classic design is truly remarkable, combining beauty and functionality in a compact package. With its sleek lines and refined contours, this lantern stands out with its distinctive and eye-catching appearance. The Olight Olantern Classic Mini boasts a sleek and compact appearance that exudes modern elegance.
Despite its small size, it manages to pack a powerful punch, providing ample illumination in any setting. One of the standout features of the Olantern Classic is its weight. Weighing in at 47% lighter than its predecessor, it is incredibly lightweight and easy to carry, making it perfect for outdoor adventures or everyday use. The Olantern Classic's design is a testament to Olight's commitment to innovation and creating products that are not only efficient but also aesthetically pleasing.
The lantern's surface is adorned with a smooth matte finish, providing a comfortable touch and a sophisticated look. The Olantern Classic Mini is designed to provide flexibility and versatility in its usage. It features a 1/4 thread, which allows you to easily attach and mount the lantern onto various DIY brackets. This unique feature enables you to create your own customized lighting setup according to your specific needs or preferences.
By combining the Olantern Classic Mini with a DIY bracket, you can optimize its placement and achieve the perfect lighting arrangement for any situation, be it camping, photography, or other outdoor activities.
The top of the lantern is adorned with a sturdy stainless steel handle for easy carrying and hanging options. Whether you want to hang the lantern from a tree branch, mount it on a tripod, or secure it to a custom-made bracket, the 1/4 thread ensures compatibility and ease of use. The ability to personalize and customize your lighting setup adds an extra dimension of convenience and creativity to the Olantern Classic Mini.
With its minimalist design and refined aesthetics, the Olight Olantern Classic Mini is not only a functional lighting tool but also a stylish accessory that effortlessly complements any environment.
GENERAL DATA | |
Max Output | 300 lumens |
Max Runtime | 60 hours (Low mode) |
Charge type | Type-C Charging Cable |
Max Throw | 360-Degree Lighting Distribution |
Powered By | Rechargeable 16.65Wh (4500mAh / 3.7V) Li-ion Battery |
| Light Source | Warm Light LEDs, White Light LEDs |
| Dimensions | Length: 4.86in/123.5mm Cap Diameter: 4.33in/110mm |
| Weight | 14.64oz/415g |
| Body Material | Metal |
| Warranty | Olight’s 2-Year Warranty |
| Waterproof | IPX5 |
| Drop Test | 0.8M |
What's in the box?
Olantern Classic Mini x 1
Type-C Charging Cable x 1
User Manual x 1
The Olantern Classic Mini is equipped with a built-in 21700/4500mAh battery, ensuring extended usage and exceptional performance. Designed to provide long-lasting illumination, this powerful battery enables the lantern to offer an impressive battery life of up to 60 hours. Whether you're camping, hiking, or simply need reliable lighting for an extended period, the Olantern Classic Mini has you covered.
The Olantern Classic Mini offers a convenient power bank function. With this feature, it becomes an essential companion for those times when you need emergency charging for your mobile phone or other devices. The Olantern Classic Mini is equipped with a powerful battery that can fully charge an iPhone 14, ensuring that you stay connected and powered up even in critical situations.
Lighting modes
The Olantern Classic Mini boasts dual light sources, offering both warm light and white light options. Here are the key points about this feature: With a simple shake or tap, you can effortlessly switch between different light sources, whether it's warm light or white light. Ranging from a gentle 5 lumens to a powerful 300 lumens, this lantern provides a customizable lighting experience like no other.
Warm Light: The warm light setting provides a cozy and inviting glow, perfect for creating a relaxing ambiance or adding a touch of warmth to your surroundings.
White Light: The white light option offers a brighter and more crisp illumination, ideal for tasks that require enhanced visibility or for illuminating larger areas.
Led and Beam
Olantern Classic Mini's beam design is carefully crafted to distribute light evenly, providing a balanced and wide coverage area. The Olantern Classic Mini incorporates three LED filaments that emit a warm "orange light" (2000-2100K). In addition, there are four SMD LEDs positioned on a PCB in the top shade, just above where the polycarbonate globe is mounted.
Furthermore, there is a ring of SMD LEDs located behind a diffuser referred to as "warm white" (5000-5500K). It is worth noting that this may not align with the conventional definition of "warm white." The lantern features a single control knob that allows for seamless adjustment of the brightness of the warm LED filaments. As you continue to rotate the knob, the neutral LEDs gradually take over, providing a smooth transition in brightness.
Beamshots
These lanterns are hanging in a pine tree approximately 3 meters away.
Application
The Olantern Classic Mini is designed to meet a wide range of lighting needs, making it suitable for various purposes. For camping enthusiasts, this lantern provides reliable and adjustable illumination, ensuring you have ample light to navigate outdoor spaces and set up camp.
Moreover, its warm light option makes it an excellent choice for creating a cozy and inviting atmosphere in your bedroom or any other indoor space. Whether you need bright and focused lighting for reading or prefer a softer glow for relaxation, the Olantern Classic Mini can cater to your specific requirements.
Additionally, its versatile design makes it a great option for decorating your living space, adding a touch of warmth and ambiance to any occasion. With its ability to adapt to different lighting scenarios, the Olantern Classic Mini is a versatile lighting solution that can enhance your camping experience, elevate the ambiance of your home, and meet various lighting needs with ease.
Comparison with Olantern Classic Pro 2
The Olantern Classic Mini offers the same level of lighting performance as its counterpart, the Olantern Classic 2 Pro , while being substantially smaller and lighter in size. This compact design makes it incredibly convenient for travel and outdoor activities where space is limited and weight is a concern. Despite its smaller form factor, the Olantern Classic Mini doesn't compromise on illumination power or quality.
| Item | Olantren Classic 2 Pro | Olantern Classic Mini |
| Max. Performance (lumens) | 300 | 300 |
| Light From | Orange LEDs, Warm White LEDs | Warm Light LEDs, White Light LEDs |
| Max Runtime | 180 hours | 60 hours |
| Mode Operation | Rotary Knob Switch | Rotary Knob Switch |
| Materials | Metal | Metal, PC |
| Compatible Batteries | Built-in 3.6V 11200mAh Rechargeable Battery Pack (4 x 18650) | Rechargeable 16.65Wh (4500mAh / 3.7V) Li-ion Battery |
| Charge type | USB-C or Olight MCC charging cable | Type-C Charging Cable |
Weight (g / oz) | 26.69 oz (756.6 g) | 14.64 oz (415 g) |
Length (mm / in) | 7.32 in (186 mm) | 4.86 in (123.5 mm) |
Cap Diameter | 4.88 in (124 mm) | 4.33 in (110 mm) |
Use | Indoors, Outdoors | Indoors, Outdoors |
| Original Price | $145.95 | $92.95 |
