For men who are kids at heart, give a light with a fun first use and a practical second one. A colour-changing orb suits a Christmas table, a white-and-RGB clip torch suits small outdoor jobs, and a handheld colour torch suits outdoor enthusiasts. Keep UV for adult inspection and use steady visible light around children.
| What he enjoys | Light type | Feature worth checking | Model |
| Backyard dinners and camp meals | Diffuse colour-changing orb | Dimmable white and a steady colour mode | Obulb Pro S |
| Setting up camp and trying gadgets | Pocket clip torch | Hands-free mount plus steady white and RGB | Oclip Pro S |
| Taking a larger torch to the campsite | Handheld RGB flood and spot torch | Selectable colour and separate white modes | Marauder Mini |
| Lighting a large open area on private property | White-light search torch | Separate flood and spot with a readable battery display | Marauder 3 |
For a summer table, let the light do two jobs
Pick an orb for someone who likes getting people around a table. At a Christmas lunch that runs into the evening, set it among the plates on dim white while you clear up. Once the table is free, use a steady colour for cards or as a marker for a game. Put the orb on a stable surface where it can light the tabletop without sitting at anyone’s eye level.
Obulb Pro S has a bottom switch with stepless dimming. Olight Hub adds colour and brightness controls and a battery readout via Bluetooth. If the recipient usually leaves their phone in the tent, try the bottom switch before giving it to them. Olight lists a maximum of 240 lumens and an IPX7 rating. The longest advertised runtime applies to the lowest setting. For a long dinner, check the battery at the intended brightness beforehand.
Stepless dimming and Bluetooth controls let this rechargeable orb switch from usable white light to steady colour. The base is magnetic.
View Obulb Pro SFor a gadget fan, choose a clip he can put to work
The best test of a novelty gift is the next ordinary job. Clip a light to a bag strap while unloading it or set it on a stable steel surface while sorting the camp kitchen. Use steady white to see the contents and a steady colour to make the bag easy to pick out when you return. Colour helps mark the location. Keep white light handy for reading labels and working on uneven ground.
The Oclip Pro S combines white, red, green and blue light with a separate UV mode. The Australian product page lists a white-light maximum of 600 lumens and 365 nm for UV. Brightness and visibility of a coloured setting depend on distance, background and ambient light. Try the actual spot at dusk before relying on it as a marker, and keep the marker on your own gear.
The Oclip Pro S clips, hangs or attaches magnetically and charges by USB-C. Its dedicated UV mode is for adult inspection.
View Oclip Pro SFor an adult checking old stains on fabric, UVA may make some residues fluoresce. Detergents and some fibres also glow, so treat the result as a prompt for closer inspection. On a camping trip an adult may see a scorpion fluoresce under UV. Leave it undisturbed and use ordinary white light to see where you are walking. A UV source can expose eyes and skin even when the beam looks dim. Keep it for adults, use suitable UV-blocking eye protection as the instructions call for, and avoid reflections or direct exposure. (Source: ARPANSA on ultraviolet exposure and health)
For more room outdoors, choose the right Marauder
Marauder Mini is the colour option in this guide. It has dedicated RGB emitters as well as white flood and spot. Consider it for an adult who already uses a handheld torch on camping trips and wants a colour mode for a steady marker or for lighting up a prop. At a crowded camp table an orb is easier to share. Aim the handheld beam at an object or the ground well clear of the group.
The original Marauder Mini has separate coloured emitters and a manufacturer-rated maximum white flood of 7,000 lumens. The colour modes have their own output.
View Marauder MiniMarauder 3 is the heavier, specialist option for an adult who also has a large area to check on private property. It has white flood, white spot and a combined mode. Olight rates its peak white flood at 25,000 lumens and dedicated spot distance at up to 1,000 m. Those are separate modes. Use the manufacturer’s moderate settings and runtime display to plan a longer job. A yard with neighbours close by needs a smaller, steadier light aimed down.
A dedicated white search torch with selectable beam coverage, a runtime display and USB-C charging. Choose it when beam reach is the reason for the gift.
View Marauder 3Match the settings and build to the way he will use it
| Summer scene | Brightness to look for | Runtime to plan | Water and mounting check |
| Dinner until late | Low diffuse white that lights the whole table | Dinner and pack-up at the chosen steady setting | Stable base, with outdoor use within its rating |
| Setting up a tent | Even white spill close to hands | Setup plus one later trip at a useful white setting | Secure clip and a closed charging cover if fitted |
| Marking gear for a game | Steady colour visible against the actual background | The intended session in the selected colour | Stable position off the walking route |
| Checking a large open area | White spot for distance, flood for near surroundings | Usable lower settings across the whole check | Protected charging port and a grip that stays secure |
Quick comparisons miss the parts you use daily. Look at the switch, clip hinge and charging cover first. A light that uses a cable the recipient can find and holds firmly where they plan to put it will be easier to use. A water rating describes protection under specified conditions. Dry the charge area before plugging in and follow the product’s care instructions. Compare the stated runtime for the same kind of mode across products.
Use steady visible light around children
For a backyard game, place a dim, steady colour next to the game pieces and keep enough white light on the route to see steps, stakes and hoses. An adult should control bright handheld beams. Keep light below face level, avoid flashing modes in a group and keep UV out of the game. Leave the laser and high-output settings out of any activity with children.
Charge rechargeable lights where an adult can see them, on a hard surface away from bedding and direct sun. Use the manufacturer’s recommended charger or cable, stop using a damaged or swollen battery product and store it somewhere cool and dry. For any extra novelty light, check for accessible button batteries and choose a design without them where possible. (Source: ACCC lithium-ion battery guidance) (Source: ACCC button battery guidance)
A small gift can be more memorable when it comes with something to do that evening. Put an orb beside a pack of cards or give a clip torch with a note naming the trip it is for. Explore the Australian best sellers for other gift ideas.
Frequently asked questions
What is the five-gift rule for men?
One version suggests something he wants, something he needs, something to wear, something to read and an activity to share. A table light and a game to play under it can cover the wish and the shared activity with two gifts.
What is a gift every man wants?
Start with a habit you have actually seen. Someone who hosts outdoors can use a dimmable orb on the table. A camper who regularly clips tools to a bag may get more use from a compact white-and-colour clip torch.
What are useful gifts for men who enjoy gadgets?
A rechargeable table light, clip torch, torch for outdoor jobs, power bank, gear pouch, insulated bottle, camp mug, small tool organiser, repair kit or outdoor game can work. Choose by a specific use and favour controls he can use without the manual for the basic task.
