We have recently introduced the Seeker 4 Pro, the latest addition to its Seeker series. Building upon the success of its predecessor, the Seeker 3 Pro, the Seeker 4 Pro brings forth a range of upgrades and improvements that elevate its performance and user experience.
In this article, we will explore the key enhancements of the Seeker 4 Pro and compare them to its predecessor, the Seeker 3 Pro, to understand what sets it apart.
| ITEMS | Seeker 4 Pro | Seeker 3 Pro |
| Max Output | 4600 Lumens | 4200 Lumens |
| Max Throw | 260 Meters | 250 Meters |
| Charging Type | Type-C / MCC3 | MCC3 |
| Compatible Batteries | Customized 3.6V 5000mAh 21700 | Customized 3.6V 5000mAh 21700 |
| Light Source | Neutral White LED (4000K~5000K) Cool White LED (5700K~7000K) | Cool White LED (5700K~7000K) |
| Lens / Reflector Type | TIR Optic Lens | TIR Optic Lens |
| Weight | 7.23 oz (205 g) (Including Battery) | 7.06oz/200g (Including Battery) |
| Holster | With Holster | No Holster |
Output & Throw
Seeker 4 Pro: The Seeker 4 Pro is a top-tier flashlight that offers a maximum output of 4,600 lumens, 10% higher than the Seeker 3 Pro. With a beam distance of up to 260 meters, this torch delivers a long-reaching, focused beam that can illuminate objects at a significant distance.
Seeker 3 Pro: The Seeker 3 Pro offers a maximum output of 4,200 lumens, just slightly lower than the Seeker 4 Pro. It has a beam distance of up to 250 meters, providing ample reach for most lighting needs.
Side Switch
Seeker 4 Pro: Seeker 4 Pro includes a metal side button with stepless dimming, enhanced surface friction for easier button rotation, and a hidden dashboard design for a futuristic feel. 1,200+ micro holes are created on the metal bezel. enhancing indicator visibility while offering a futuristic and elegant appearance. These holes are then sealed with a waterproof material to keep their reliable IPX8 waterproof rating
Seeker 3 Pro: Seeker 4 Pro includes a silicone button, surrounding the rotary knob are the indicators to reveal the brightness and battery levels in real-time.
LEDs & Lens
Seeker 4 Pro: Equipped with four Osram P9 LEDs and a high-end TIR lens, it provides uniform and soft lighting for various scenarios.
Seeker 3 Pro: Equipped with four high-performance cool white LEDs
Charging Options
Seeker 4 Pro: Type-C charging (with Holster) or MCC3 magnetic charging (MCC3 2A charging).
Seeker 3 Pro: It can be charged by an MCC3 charging cable with a current of up to 2A
Color Temperatures
Seeker 4 Pro: Two Color Temperatures Available, Select between two different color temperatures: cool white (5700K~7000K) or neutral white (4000K~5000K). Only Black colour has two colour temperatures.
Seeker 3 Pro: Seeker 3 Pro only has a cool white temperature available.
Anti-slip Grip
Seeker 4 Pro: The Seeker 4 Pro features an ergonomic wrap-around silicone grip that provides a secure and comfortable hold even in wet conditions, showcasing exceptional craftsmanship for the ultimate grip experience.
Seeker 3 Pro:
Holster
Seeker 4 Pro: It comes with a standard Holster for convenient storage and placement options. As an industry-leading and innovative holster, this groundbreaking design offers flashlight auto lock/unlock, charging, storage, and carrying options.
Seeker 3 Pro:
