A swollen lithium-ion battery indicates internal gas accumulation from overcharging, cell degradation, or high-temperature exposure. **Immediately power off the device, isolate the swollen cell in a non-combustible container (such as a metal bucket with sand or a fireproof LiPo bag), and never puncture, press, or charge it.** In Australia, swollen batteries must not be thrown into household red bins; they must be disposed of safely through certified **B-cycle drop-off points** (Bunnings, Officeworks, Woolworths, or local council chemical collection hubs).
A swollen battery is caused by gas build-up during thermal breakdown or overcharging, posing an immediate fire hazard. First, disconnect charger power instantly, isolate the battery in a fireproof container, and never squeeze or pierce the casing. Dispose of damaged cells safely through official Australian B-cycle collection points.
- 1. Quick Answer: Immediate Do and Do-Not List
- 2. Assessing Severity and Thermal Runaway Risks
- 3. Removing a Stuck Swollen Cell Safely
- 4. Disposal: B-cycle and Council Drop-Off Points in Australia
- 5. What do you do with a swollen battery?
- 6. Is a swollen battery dangerous?
- 7. Where do you dispose of lithium batteries in Australia?
- 8. Frequently Asked Questions (FAQ)
Discovering a swollen lithium-ion cell in your high-performance torch, headlamp, or power bank requires prompt, calm action. Swelling occurs when internal electrolyte liquid decomposes into flammable gases (oxygen, carbon monoxide, and hydrogen) due to overcharging, physical impact, or excessive thermal stress during hot Australian summers. To maintain total safety, follow this strict protocol immediately:
- Unplug charger from power outlet instantly.
- Isolate the battery in a metal bucket filled with dry sand or a LiPo fireproof safety bag.
- Store in a cool, well-ventilated outdoor area away from timber decks and dry leaves.
- Cover battery terminals with electrical tape to prevent short circuits.
- NEVER attempt to charge or discharge a swollen cell.
- NEVER puncture, squeeze, or pop the swollen casing.
- NEVER use metal screwdrivers or pliers to force out a stuck cell.
- NEVER throw into household rubbish or yellow recycling bins.
To learn more about battery cell chemistries and proper charging protocols, explore our guide on 18650 vs 21700 lithium batteries or view our full range of high-performance LED torches.
Lithium-ion batteries maintain internal chemical stability through delicate separator membranes. When internal gas builds up, swelling creates mechanical stress that can breach internal insulators. Assessing cell condition helps determine whether a swollen battery requires basic isolation or emergency fire response.
When a cylindrical 21700 or 18650 battery swells inside a torch battery tube, radial expansion wedges the battery tight against the internal aluminum walls. Attempting to pry the cell out with metal dental picks, screwdrivers, or pliers risks puncturing the nickel-plated steel jacket, instantly triggering a dead short and aggressive thermal runaway.
Safe Mechanical Extraction Method: First, wear safety goggles and thick leather work gloves. Unscrew both the tailcap and head bezel of the torch if possible. Next, clean the exposed flat terminal of the stuck battery with isopropyl alcohol. Apply a strip of high-tack duct tape or heavy-duty Gorilla tape firmly to the exposed negative terminal, leaving a 10 cm folded tail loop. Gently pull the tape loop along the central axis of the tube while holding the torch body. If the cell remains immobile, place a smooth wooden or plastic dowel rod against the front terminal (head side) and lightly tap the wood with a rubber mallet to slide the battery out backward.
In Australia, disposing of lithium-ion batteries in kerbside general waste (red-lid bins) or yellow recycling bins is illegal across most municipalities. Waste collection vehicles compress garbage, easily crushing compromised lithium cells and causing severe fires in garbage trucks and recycling sorting facilities.
If you discover a swollen battery, turn off the device immediately and disconnect any charging cables. Cover the battery terminals with electrical tape to prevent short circuits, place the cell inside a non-combustible container like a metal tin filled with sand or a LiPo safety bag, and take it to an official B-cycle battery recycling drop-off point. Never attempt to charge, puncture, or crush a swollen battery.
Yes, a swollen battery is dangerous. Swelling indicates that internal gas pressure has built up due to chemical breakdown or damaged internal separators. Puncturing or continuing to charge a swollen cell can trigger a violent thermal runaway, releasing toxic fumes and intense fire that cannot be extinguished with standard water fire extinguishers.
In Australia, lithium batteries must be disposed of at certified battery recycling drop-off points certified under the B-cycle scheme, including major retailers like Bunnings, Officeworks, Woolworths, ALDI, and Battery World. Heavily damaged or severely swollen batteries should be taken to local council chemical waste collection facilities.
Last Updated: September 2026. Published with swollen lithium battery safety extraction procedures, thermal runaway prevention guides, and official Australian B-cycle recycling network drop-off protocols.
What fireproof battery safety containers do you use when storing high-capacity 21700 cells?
