Considering Olight's brand new product, the Perun 2 mini Headlamp, if you are looking for a hands-free flashlight that does so much, is something I strongly recommend. A new version of the popular Perun Mini, the Perun 2 Mini was released. The Perun 2 mini is a high-lumen rechargeable right-angle flashlight that combines white and red LED options.
It is a versatile, portable light that can also be used as a headlamp using the upgraded headband, meeting a variety of lighting needs at home, outdoors, at work, etc. Do you want to learn more about this powerful headlamp? What has been upgraded from Perun 2 mini? Does it have any special features? Let me tell you now!
Perun Mini VS Perun 2 Mini
Product | Perun 2 Mini | Perun Mini |
Max. Performance (lumens) | 1100 | 1000 |
Beam Distance(m) | 150 | 100 |
Light Intensity (candela) | 5950 | 2500 |
Compatible Batteries | Customized 650mAh 3.6V IMR16340 Rechargeable Lithium Battery (included) | Customized 550 mAh 3.7V IMR16340 |
Charge type | MCC1A Magnetic Charging | Magnetic USB charge base |
Body Diameter (mm / in) | 0.81in/20.6mm | 0.81in/20.6mm |
Head Diameter (mm / in) | 0.87in/22mm | 0.83in/21mm |
Length (mm / in) | 2.52in/64mm | 2.42in/61.6mm |
Weight (g / oz) | 1.90oz/54g (including battery) | 1.83oz/52g (including battery) |
Waterproof | IPX8 | IPX8 |
Light Form | High-Performance Cool White LED and Red LED (Black&Lime Green &Orange); High-Performance Neutral White LED and Red LED (Black) | Wide/broad hotspot. Perfect for up- close illumination. |
01. Same size, but brighter
In keeping with the mini-sized Perun Mini, Its length is only 64.3mm, the head diameter is 22mm, the body diameter is 20.6mm, and it weighs only 54 g. High-performance LED light source and TIR lens combine to produce luminous flux up to 1100 lumens and a range of 150 meters, making it suitable for medium and short-distance lighting
02. Combine with White And Red LEDs
The white light can output up to 1100 lumens in two color temperatures (cool white/medium white), with a choice of 5700K(warm white) and 4000K(medium white) to meet the needs of various lighting scenarios. Two high-lighting red lights, the LED red light penetrates deeply, can be used for emergency warning and insect observation, the maximum brightness is 40 lumens, and SOS mode can be turned on to signal for help.
03. Larger battery capacity
As an upgrade to the Perun Mini, it has 18% longer battery capacity. With a battery capacity of 650mAh, the Customized 3.6V 16340 rechargeable lithium battery offers a max. the runtime of 240 hours on moonlight mode.
04. Visible battery status
You can now quickly and intuitively determine the remaining power status with a three-color Power Indicator light in the middle of the button. Three colors accurately indicate the remaining power. (Green:>60%,Orange:60%~10%, Red:10%~5%,Flashing Red:<5%).
05. Upgraded headband
By reducing the contact area between the headband and the skin, it becomes more comfortable and lighter. It's stable and more comfortable to wear.
06. 180° Multi-Angle Lighting
With its solid base, you can quickly and easily adjust the lighting angle over 180° arc, and it will stay in place. Make sure that the lighting is not dead angle.
07. Simple magnetic charging
Featuring a USB magnetic charging cable, the Perun 2 mini is easy and fast to charge. The MCC 1A magnetic charging cable snaps on instantly and gets charging started right away.
08. Everywhere with you
Equipped with a removable stainless steel pocket clip, it can be easily clipped to pockets, backpacks, and belts. Attach it to a hat brim or backpack strap. Carry it in a pocket. It's an ideal companion for EDC lighting needs.
09. Introduction Video
10. Get yours
The Olight Perun 2 Mini is a very compact yet powerful flashlight. They are available in a few different colors as well as 2 LED options. Are you interested in Perun 2 mini? Maybe you should have a try. Click here to get yours>>>>
