TL;DR: The next-generation Olight Perun X and Perun Ultra redefines hands-free lighting. Featuring an industry-first single glass optical lens combining spotlight, pure floodlight, and night-vision red light, this high-performance head torch delivers up to 2,400 lumens. Built with a 4,000mAh battery, IPX7 waterproofing, DialFit adjustment, and dual USB-C/magnetic charging, it is the ultimate headlamp and right-angle torch light for camping lights setups, automotive repair, and extreme outdoor adventures.
As the warm outdoor season approaches in Australia, gear prep for weekend camping trips, night fishing off the coast, and late-night property maintenance is in full swing. When tackling the unpredictability of the Australian bush or working in cramped engine bays, generic flashlights often leave you struggling in the dark with compromised mobility. Navigating rugged terrain after dark requires reliable, powerful illumination that leaves your hands completely free to haul gear, set up camp, or handle complex equipment. Olight is proud to launch the all-new Perun X and Perun Ultra headlamps—redefining what a high-performance head torch can achieve under the mantra: "Head to hand. Always in focus."
- Three Beams in One Glass Lens: Spot, Pure Flood, and Red Light
- Seamless Transition: From Headlamp to Right-Angle Torch Light
- Intuitive Rotary Control & Laser-Etched Status Indicators
- Superior Comfort with the Bidirectional DialFit System
- Rugged Reliability: Premium Alloys, Proximity Sensing & IPX7 Waterproofing
- Long-Lasting 4,000mAh Power Platform & Dual Charging
- Technical Specifications Comparison
At the core of the Perun X and Perun Ultra is an industry-first single glass optical lens that integrates three distinct light sources: precision spotlight, pure floodlight, and red light mode. Combined Spot + Flood mode pushes up to 2,000 lumens (22,500 cd) on the Perun X with a 300-meter reach, and a staggering 2,400 lumens (30,625 cd) extending up to 350 meters on the Perun Ultra. Both models offer up to 1,000 lumens of pure floodlight for illuminating broad work areas without harsh glare, as well as a dedicated 60-lumen red light mode (including SOS signaling) to preserve dark adaptation during night fishing, stargazing, or emergency signaling. Rigorously tested in accordance with ANSI/PLATO FL 1 Performance Standards, this headlamp seamlessly covers every distance to keep you focused and safe.
The versatility of the Perun series shines through its quick-release bracket system, designed to solve the hassle of swapping between different light tools during multi-tasking operations. In seconds, you can unclip the unit from its headband bracket and convert it into a compact, right-angle torch light. Featuring a heavy-duty stainless steel pocket clip and a strong magnetic tailcap (MCC contact point), you can attach it to gear straps, hang it inside tents, or snap it magnetically to metal vehicle bonnets, toolboxes, or machinery for instant hands-free lighting.
Olight Perun X
Reliable 2,000-lumen headlamp featuring an integrated single glass lens (Spot/Flood/Red), AL6061-T6 aluminum body, quick-release bracket, and fast USB-C & MCC charging.
Shop Perun X →Intuitive Rotary Control & Laser-Etched Status Indicators
Operating your light should be effortless, even in high-stress situations. The Perun series features an ergonomic rotary light selector paired with a central power and brightness button. Simply twist the dial to select between spotlight, floodlight, or red light, and press the button to adjust brightness levels. Both models come equipped with a clear battery level indicator. Taking user feedback further, the Perun Ultra introduces a micro-perforated, laser-etched display that showcases both battery levels and active brightness levels directly through the metal housing for instant feedback.
Long hours of wear require superior comfort, especially during grueling overnight treks or long shift repairs where traditional headbands start to pinch or slip. Both models utilize a wide 35mm breathable headband equipped with reflective safety strips for 360-degree night visibility. While the Perun X features a classic buckle adjustment system, the Perun Ultra introduces an innovative bidirectional DialFit System DialFit adjustment dial. This allows precise, single-handed micro-tightening and loosening even while wearing heavy work gloves—delivering a customized, non-bounce fit tailored for high-intensity activity.
Engineered for demanding Australian environments, the Perun X is constructed from lightweight AL6061-T6 aluminum alloy (available in Black and Orange), while the flagship Perun Ultra upgrades to high-strength, scratch-resistant OAL (Olive Green) alloy. Both lights feature a heat- and scratch-resistant glass optical lens, certified IPX7 waterproofing (withstand submersion up to 1 meter for 30 minutes under IEC Standard 60529), and 1.5-meter drop resistance. To ensure maximum safety during close-up tasks, built-in smart thermal control is paired with an infrared optical proximity sensor that automatically reduces output when an obstruction is detected within one second of activating High or Turbo modes to prevent heat buildup or fabric scorching.
Olight Perun Ultra
Flagship 2,400-lumen hands-free solution with ultra-hard OAL alloy casing, bidirectional DialFit System DialFit adjustment headband, laser-etched status display, and 350-meter throw.
Shop Perun Ultra →Long-Lasting 4,000mAh Power Platform & Dual Charging
Powered by a high-capacity 4,000mAh 18650 battery platform, both models deliver exceptional endurance, including up to 33 days of continuous runtime in 1-lumen Moonlight mode. Charging versatility is a key highlight: each light features a built-in USB-C charging port with a protective cover, while retaining full support for optional Olight MCC3 magnetic charging cables. Whether you are recharging via solar panels, power banks, or magnetic workshop docks, these camping lights ensure you stay powered and ready for action.
| Feature / Specification | Perun X | Perun Ultra |
| Max Output (Spot + Flood) | 2,000 Lumens | 2,400 Lumens |
| Max Beam Distance | 300 Meters (22,500 cd) | 350 Meters (30,625 cd) |
| Body Material | AL6061-T6 Aluminum Alloy | High-Strength OAL Alloy |
| Weight (Net) | 120 g / 4.23 oz | 130 g / 4.59 oz |
| Headband Adjustment | Standard Adjustment Buckle | Bidirectional DialFit System |
| Status Display | Battery Level Indicator | Laser-Etched Battery & Brightness Indicators |
| Available Colors | Black, Orange | Olive Green |
| Waterproof & Drop Rating | IPX7 Waterproof, 1.5m Drop Resistance | IPX7 Waterproof, 1.5m Drop Resistance |
What is the main difference between the Perun X and the Perun Ultra?
The Perun Ultra delivers higher maximum brightness (2,400 lm vs. 2,000 lm), longer throw distance (350m vs. 300m), an upgraded high-strength OAL alloy body, a laser-etched brightness & battery indicator display, and the DialFit System headband adjustment system for effortless one-handed tuning.
Can I charge the Perun X / Ultra with a standard USB-C cable?
Yes! Both models feature a built-in USB-C port protected by a rubber cover, while retaining support for optional Olight MCC3 magnetic charging cables for flexible power management anywhere.
Is this headlamp suitable for night fishing and preserving dark vision?
Absolutely. Both models feature a dedicated 60-lumen red light mode (with low, moonlight, and SOS options) that preserves night-adapted vision during night fishing or nocturnal trail navigation.
Whether you need dependable camping lights for bushwalking, an emergency backup light for power cuts, or a rugged head lamp for professional automotive repair, the Olight Perun X and Perun Ultra set a new benchmark for hands-free illumination. Don't let the dark limit your focus—invest in reliable gear built to keep pace with your active lifestyle. Elevate your setup today and experience true hands-free performance.
