Table of Contents 1. The Next Generation of Olight Batons Arrives in Australia
2. At a Glance: Key Specifications Comparison
3. Baton 4 Pro: The Balanced Performer for Everyday Tasks
4. Baton Ultra: Pushing the Boundaries of Outdoor Innovation
5. What They Have in Common: Features We Love
6. Which One Should You Choose? (Finding Your Perfect Match)
7. Conclusion: Elevate Your EDC Today
8. Everything You Need to Know About the New Baton Series(FAQ)
For outdoor adventure enthusiasts in Australia, the search for the ultimate Every Day Carry (EDC) light often involves balancing raw power with pocketable dimensions. Olight has consistently met this demand with the Baton series, but the 2026 evolution marks a significant leap forward. The introduction of the Baton 4 Pro and the Baton Ultra sets a new standard for compact cylindrical illumination.
These models are not just incremental updates; they represent a fundamental shift in how portable lighting functions in the field. Whether you are navigating the rugged trails of the Blue Mountains or performing maintenance tasks in a dimly lit workspace, these tools provide high-intensity output combined with innovative dual-charging capabilities. Both the Baton 4 Pro and Baton Ultra are engineered to endure the harsh Australian environment while offering intuitive controls that outdoor enthusiasts demand.
To understand the positioning of these two flagship models, a direct comparison of their technical parameters is essential. While they share the same DNA, their performance profiles cater to different operational needs.
| Feature | Baton 4 Pro | Baton Ultra |
| Max Performance | 1,600 lumens | 1,800 lumens |
| Max Throw | 200 meters | 300 meters |
| Max Light Intensity | 10,000 candela | 22,500 candela |
| Light Source | High Performance LED | EIP 1 (Self-developed) |
| Body Material | 6061 Aluminum | OAL™ (O-Aluminum) |
| Weight (incl. battery) | 114 g (4.02 oz) | 115 g (4.06 oz) |
| Max Runtime | 100 days (Moonlight) | 100 days (Moonlight) |
| Waterproof Rating | IPX8 | IPX8 |
| Charging Type | USB-C and MCC3 | USB-C and MCC3 |
The **Baton 4 Pro** serves as the versatile workhorse of the lineup. It is designed specifically for those who require a dependable light for a mix of professional work, home use, and general outdoor activities. It strikes a precise balance between flood and throw, making it an ideal companion for close-to-mid-range tasks.
Power Meets Portability (1,600 Lumens)
Despite its compact cylindrical form, the Baton 4 Pro delivers a formidable 1,600 lumens in Turbo mode. This level of output is sufficient to illuminate an entire backyard or a large workshop. With a 200-meter beam distance, it provides excellent situational awareness without the bulk of a traditional searchlight.
Improved Thermal Control: Keeps Its Cool in the Heat
One of the primary challenges with high-lumen compact lights is heat management. The Baton 4 Pro features an advanced **thermal control system** designed to keep the surface temperature below 45 °C. This is a critical safety feature for Australian users, ensuring the light remains comfortable and safe to handle even during high-output operation in warm climates.
The Baton Ultra is the pinnacle of the 2026 series, incorporating proprietary technology that pushes the limits of what a compact EDC light can achieve. It is specifically tailored for long-range outdoor use, such as hiking, search operations, or nighttime exploration.
Olight’s Self-Developed LED: The EIP 1 Advantage
At the heart of the Baton Ultra lies the EIP 1, a self-developed LED utilizing a non-uniform electrode design. This proprietary technology provides approximately 10% higher luminous efficiency during high-power operation compared to standard LEDs. The result is a crystal-clear, natural white beam that reproduces colors accurately.
Built Tough with Superalloy OAL™ (O-Aluminum)
The Baton Ultra is constructed from OAL™ (O-Aluminum), a superalloy developed by Olight. This material offers superior hardness and scratch resistance compared to standard aluminum. For outdoor adventure enthusiasts, this means the light can withstand the inevitable drops, scrapes, and abrasions encountered in the bush.
300-Meter Throw: Seeing Further into the Night
The Baton Ultra excels in distance. With a maximum light intensity of 22,500 candela and a **300-meter throw**, it significantly outperforms most lights in its size class. This extended reach is invaluable for spotting trail markers or identifying distant landmarks during camping trips.
While their performance targets differ, both models benefit from shared engineering excellence that defines the modern Olight experience.
Dual Switches & Dual Charging: Ultimate Convenience
The user interface features a dual-switch design for intuitive control. Charging versatility is another standout feature; both lights utilize Olight’s signature **MCC3 magnetic charging** plus a hidden USB-C port located behind a smooth, rotating tailcap ring.
Battery Life That Goes the Distance (100-Day Runtime)
Both models are powered by a high-capacity 3,500 mAh 18650 battery. This ensures remarkable longevity, with a maximum runtime of **100 days** when used in Moonlight mode—perfect for emergency situations or multi-day treks.
Choosing between the Baton 4 Pro and the Baton Ultra depends on your primary use case:
Select the Baton 4 Pro if:
- Your primary needs are everyday tasks, home maintenance, or professional trades.
- You prefer a balanced beam that is useful for both indoor and outdoor settings.
- You prioritize thermal comfort during extended high-output use.
- You want high performance at a standard aluminum weight.
Select the Baton Ultra if:
- You are a dedicated hiker, camper, or outdoor adventurer who needs maximum distance.
- You require the highest possible durability and scratch resistance (O-Aluminum).
- You value cutting-edge LED technology for superior color rendering and efficiency.
- You need to see up to 300 meters away without carrying a heavy spotlight.
The 2026 Olight Baton series represents a significant milestone in portable lighting. The Baton 4 Pro delivers the perfect balance for daily life, while the Baton Ultra brings professional-grade long-range performance to the EDC category. With dual-charging convenience and IPX8 waterproofing, these lights are built to be lifelong companions.
FAQ – Everything You Need to Know About the New Baton Series
Q1: What is the main difference between Baton 4 Pro and Baton Ultra?
The main difference lies in performance and materials. The Baton Ultra has a higher output (1,800 lumens), a much longer throw (300m), and is made of scratch-resistant O-Aluminum. The Baton 4 Pro is optimized for balanced, everyday use with enhanced thermal control.
Q2: Does the Baton Ultra come with a USB-C charging port?
Yes, both models feature a hidden USB-C charging port located in the tailcap, protected by a rotating ring. They also support Olight’s MCC3 magnetic charging.
Q3: How durable are these flashlights?
Both lights are IPX8 waterproof (submersible up to 2 meters). The Baton 4 Pro has 1.5m impact resistance, while the Baton Ultra offers 2m impact resistance and superior scratch resistance due to its O-Aluminum body.
Q4: What is the "EIP 1" LED in the Baton Ultra?
EIP 1 is a proprietary LED developed by Olight. It features a non-uniform electrode design that increases efficiency by 10% and provides a clear, natural white beam for better visibility.
