When darkness falls, hunters and tactical operators demand illumination that adapts to their environment. Javelot Turbo 2 and Javelot Pro 2 are engineered to dominate the night—but each excels in unique scenarios.
Below is a detailed comparison of the Javelot Turbo 2 and Javelot Pro 2, highlighting their key differences and helping you decide which long‑range hunting torch best suits your needs.
Head-to-Head Overview
| Feature | Javelot Turbo 2 | Javelot Pro 2 |
| Brightness | 1800 lumens | 2500 lumens |
| Max Beam Distance | 1,500 meters | 1050 meters |
| Battery |
7.2 V Removable Battery Pack (Two 5.000 mAh 21700 Li-ion Batteries Included) |
3.6 V Integrated Battery Pack (Two 5.000 mAh 21700 Li-ion Batteries Included) |
| Max Runtime | 272 hours | 288 hours |
| Remote Switch Type | Wireless | Wired |
| Weight | 430 g | 423 g |
| Size | 63 x 257.6 mm | 63 x 259 mm |
| Waterproof | IP67 | IPX8 |
| Price | $299.95 | $289.95 |
✅Brightness & Beam Distance
Turbo 2 Performance
- Max Output: 1,800 lumens in Turbo mode
- Throw: 1,500 meters (claimed)
- Measured Candela: ~576,715 candela
Pro 2 Performance
- Max Output: 2,500 lumens in Turbo mode
- Throw: 1,050 meters (claimed)
- Measured Candela: ~217,400 cd
In real‑world use, the Turbo 2 excels at pure throw, making it ideal for spotting game at extreme distances. The Pro 2 offers the brightest lumen output in its class, balanced by strong flood, suitable for both beam reach and close‑in visibility
✅Power & Runtime
Battery Configuration
- Turbo 2: Removable 5,000 mAh battery pack; runtime up to 272 hours on low
- Pro 2: Integrated “supersized” pack providing up to 12 days (≈288 hours) on low
Charging Options
- Both lights offer USB‑C and magnetic charging, but the Turbo 2 adds a dedicated magnetic dock for its wireless remote
- The Turbo 2’s inclusion of USB‑C is a “great step up” over its predecessor, easing field charging with common cables
✅User Interface & Extras
- Turbo 2 comes in‑box with a wireless remote pressure switch, removing cable clutter when rifle‑mounted
- Pro 2 offers an optional dual‑stage remote switch (sold separately) for press‑and‑hold momentary use
Both lights feature two physical switches (side + tail) for mode switching and instant on/off
✅Value & Pricing
- Turbo 2: AU$ $299.95 (includes wireless remote, replaceable pack)
- Pro 2: AU$ $289.95 (higher lumen output, longer internal runtime)
The Turbo 2’s premium covers its modular battery and remote, while the Pro 2 undercuts slightly for greater peak output and runtime, making each light good value depending on your priorities.
✅Which to Choose?
- Pick the Javelot Turbo 2 if maximum throw, battery modularity, and wireless remote control are your top priorities.
- Opt for the Javelot Pro 2 if you need peak brightness, versatile beam profiles, and exceptional low‑level runtime in a slightly more affordable package.
Both torches represent our cutting edge in long‑range illumination—choose based on whether you lean more toward sheer distance (Turbo 2) or balanced output plus runtime (Pro 2).
