Overview
What is a tactical torch?
How to choose a tactical flashlight?
Olight Warrior Series Review
Warrior Mini 2
Warrior 3S
Warrior X 3
Warrior X Turbo
A tactical torch is a type of flashlight designed specifically for tactical use. It is usually made of high-quality aluminum, has a tough construction, and can withstand rough handling. Tactical torches typically feature an adjustable light beam, allowing for multiple beam ranges and options for different tasks.
They often have a variety of settings and functions, such as strobe and SOS, as well as varying levels of brightness and battery life. Tactical torches have the ability to be mounted to different weapons and can be used for tasks such as search and rescue, tracking, outdoor activities, and hunting.
How to Choose a Tactical Flashlight?
When it comes to choosing a tactical flashlight, there are several important factors to consider. By considering these factors, you can find the perfect tactical flashlight for your needs.
Lumen Output:
You should consider the brightness of the flashlight. Depending on the type of activity you plan to use the flashlight for, you may need a brighter and more powerful light. For instance, if you plan to use the flashlight while hunting or fishing, you may want a brighter and larger flashlight.
Lighting Modes:
It is important to have a tac light with various lighting modes when lighting conditions change in your tactical environment. This ensures that you will always have the right amount of light to see clearly during changes in lighting conditions.
Rechargeable:
You should consider the power source of the flashlight. Most tactical flashlights use either batteries or a battery pack. Batteries are usually more convenient, but they don’t last as long as a battery pack. If you plan to use the flashlight for long periods of time, you may want to consider a battery pack.
Tactical Tail Switch:
An effective tactical professional relies on efficiency and functionality on a daily basis. The tactical tail switch can save you time and energy by cycling through the various lighting modes.
Long Runtime:
In some cases, operations may last longer than expected. Long-lasting tac lights will help keep you focused on the task at hand.
Durable Build:
You should think about the durability of the flashlight. A good tactical flashlight should be able to withstand drops and other impacts without breaking. It should also be waterproof and dustproof. Additionally, you should look for a flashlight that has a long run time and is easy to use.
Based on the features above which we need to consider when choosing a tactical flashlight, we’ve created a list of tactical flashlights from Olight Warrior seires that exemplify the above criteria:
Warrior Mini, for its five lighting modes and strobe light
Warrior 3S, for its 55 days max runtime
Warrior X 3, for its amazing 2500 lumens
Warrior X turbo, for its incredible 1000 meters beam distance
Taking a closer look at each essential feature of the best tactical flashlight, let's move on.
Warrior Mini 2 - COMPACT EDC TACTICAL LIGHT
| Body Diameter (mm / in) | 23.0 / 0.91 |
| Head Diameter (mm / in) | 25.0 / 0.98 |
| Length (mm / in) | 118.0 / 4.65 |
| Weight (g / oz) | 122g / 4.30o |
MAIN FEATURES
Max output of 1,750 lumens and 220-meter beam distance
Side switch for daily use and a tail switch for tactical operation
The three-level battery indicator tells the battery level and when to charge
Customized 3500mAh 18650 battery charges with the MCC3 magnetic charging cable
Only 4.65-inch long, easy to carry in your pocket
Warrior 3S - TACTICAL POWER WITH PROXIMITY SENSOR
| Body Diameter | 1.03 in (26.2 mm) |
| Length | 5.47in/139mm |
| Weight | 6.21 oz (176 g) (Including Battery) |
MAIN FEATURES
Up to 2,300-lumen of output
Up to 55-days of runtime
4-level battery and brightness indicators
Built-in proximity sensor that drops the brightness level
Charges easily by the MCC3 cable
Warrior X 3 - SUPERIOR TACTICAL THROWER WITH GLASS BREAKER
| Body Diameter | 1.03in/26.2mm |
| Head Diameter | 1.54in/39mm |
| Length | 5.89in/149.5m |
| Weight | 8.99oz/255g (Including Battery and Warrior Ring) |
MAIN FEATURES
Up to 2,500-lumen of output
Max beam distance reaches 560 meters
Runs up to 8 hours
Customized 5000mAh 21700 Li-ion battery
Recharged via the MCC3 charging cable
Warrior X Turbo - EXTREME DISTANCE TACTICAL LIGHT
| Head Diameter | 2.28 in (58 mm) |
| Length | 6.18 in (157 mm) |
| Weight | 10.37 oz (294 g) |
MAIN FEATURES
Max output of 1,100 lumens
Super far-reaching throw of 1,000 meters
Max runtime of 12.5 hours
Powered by a 5000mAh 21700 battery
Tactical ring, aggressive bezel, and tail switch
Get the Best Tactical Flashlight From Olight
Several of Olight Lighting's tactical flashlights are ideal for high-stakes situations. Our selection of lights ranges from heavy-duty incandescent lights to palm-sized everyday carry lights. Take a look at our inventory to find the best tactical flashlight with the most important features!
