Perun 2 Review
Right Angle Rechargeable LED Headlamp
Overview
Introduction
What's in the box
Batteries and charging
Lighting modes
Led and Beam
Beamshots
Comparison With Perun 2 mini
Video
Application
Introduction
One of the first things you notice about the Perun 2 is its sleek and modern design. The main body is made from aluminum alloy, which gives it both strength and lightness. This material is also used in the aerospace industry, so you can be sure that it is both tough and reliable. The aluminum body is coated with a durable anodized finish, which helps to protect it against scratches and corrosion.
Another feature that sets the Olight Perun 2 apart from other flashlights is its comfortable grip. The body is designed with a diamond pattern that provides a firm and secure hold, even when your hands are wet or sweaty.
The Perun 2 features a unique tri-color multi-function indicator on the side of the body, which provides quick and easy access to important settings like battery level and mode selection. The indicator is powered by a dual-layered photoluminescent inlay, which glows brightly in the dark and makes it easy to find your flashlight when you need it.
The Perun 2 includes an elastic strap that fits snugly around the user's head. The strap is adjustable, allowing users to loosen or tighten it to ensure a perfect fit. The headband also comes with a silicone mounting frame that fits over the Perun 2 flashlight, holding it securely in place. The headband's mounting frame is designed to be easy to install and remove, allowing users to quickly attach or detach the flashlight from the headband. The frame is also compatible with other Olight flashlights, so users can use it with other Olight models they may have.
GENERAL DATA | |
Max Output | 2500 lumens |
Max Runtime | 12.5 Days (Moonlight mode) |
Beam Distance | 166M |
Mode Operation | Front Switch |
| Strobe | No |
Powered By | Customized 4000mAh 21700 Battery (Included) |
| Light Source | High Performance Cool White LED |
| Dimensions | Length: 4.75in/120.7mm Head Diameter: 1.13in/28.6mm Body Diameter: 1.06in/27mm |
| Weight | 5.68oz/161g (Including Battery) |
| Body Material | Aluminum Alloy |
| Warranty | Olight’s 5-Year Warranty |
| Waterproof | IPX8 |
| Drop Test | 1.5 M |
What's in the box?
Lighting modes
Turbo Mode: This is the brightest mode available on the Olight Perun 2, boasting a maximum output of 2,500 lumens. This mode is perfect for when you need an intense, powerful beam of light to illuminate your surroundings. High Mode: This mode offers a slightly lower output than Turbo Mode, at 500 lumens. However, it still provides a strong and reliable beam of light that is perfect for everyday use. Medium Mode: This mode offers a moderate output of 120 lumens, making it a great option for tasks that require a balance between brightness and battery life. Low Mode: This mode offers a dimmer output of 30 lumens, perfect for tasks that require minimal lighting such as reading in bed or finding your way around a dark room. Moonlight Mode: This mode offers the lowest output on the Olight Perun 2, at just 5 lumens. It is designed for tasks that require minimal light output, such as checking on sleeping children or bathroom breaks during the night.
Led and Beam
Beamshots
Comparison With Perun Mini 2
| Item | Perun 2 | Perun 2 Mini |
| Max. Performance (lumens) | 2500 | 1100 |
| Beam Distance(m) | 166 | 150 |
| Mode Operation | Front Switch | Front Switch |
| Compatible Batteries | Customized 4000mAh 21700 Battery (Included) | Customized 650mAh 3.6V IMR16340 Rechargeable Lithium Battery (included) |
| Charge type | MCC3 Magnetic Charging Cable | MCC1A Magnetic Charging |
Weight | 5.68oz/161g (Including Battery) | 1.90oz/54g (including battery) |
Length | 4.75in/120.7mm | 2.52in/64mm |
Head Diameter | 1.13in/28.6mm | 0.87in/22mm |
| Body Diameter | 1.06in/27mm | 0.81in/20.6mm |
| Waterproof | IPX8 | IPX8 |
Video
Applications
✅Outdoor Activities
✅Emergency Situations
✅Tactical Operations
✅Automotive Repair
✅Home Use
