As we all know, Olight has introduced two innovative Clip-on lights: the Oclip Pro and the Oclip. Both models are designed to cater to different needs, offering a range of features that make them versatile and practical for various situations. Let’s dive into a detailed comparison to help you make an informed choice.
| Feature | Oclip Pro | Oclip |
| Lights | 3 (Floodlight, Spotlight, Red) | 2 (Floodlight, Red) |
| Brightness | 500/380/40 lumens | 300/4 lumens |
| Lens | Glass Lens | TIR Lens |
| Waterproof | IPX6 (High-pressure jets) | IPX5 (Water splashes) |
| Size | 57 x 28.05 mm | 48.5 x 21 mm |
| Weight | 53g | 30g |
| Battery | 580mAh | 280mAh |
| Charging Time | 1h 30min | 1h 30min |
Size and Design: Compact and Portable
Both the Oclip and Oclip Pro are designed to be lightweight and compact, making them easy to carry for everyday use, but there are some key differences.
Oclip Pro:
• Dimensions: 57 x 28.05 mm
• Weight: 53g
• Material: Made from 6061 aluminum, known for its durability and lightweight properties.
Oclip:
• Dimensions: 48.5 x 21 mm
• Weight: 30g
• Material: Also made from 6061 aluminum for lightweight durability.
The Oclip is noticeably smaller and lighter, making it ideal for those who want the smallest, most portable option. On the other hand, the Oclip Pro offers slightly more bulk, which provides a more robust build but still remains highly portable.
Lighting Performance: A Battle of Power and Versatility
When it comes to lighting, the Oclip Pro is the clear winner in terms of flexibility, as it offers three types of light. Here's a breakdown:
Oclip Pro:
• Lighting Modes: Three lights—Floodlight (500 lumens), Spotlight (380 lumens), and Red Light (40 lumens).
• Lens Type: Glass lens for the floodlight and spotlight, providing clear and high-quality light output.
Oclip:
• Lighting Modes: Two lights—Floodlight (300 lumens) and Red Light (4 lumens).
• Lens Type: TIR lens for more focused light and efficient beam distribution.
While the Oclip provides sufficient lighting for basic tasks, the Oclip Pro shines in its ability to adapt to various environments with its three different light sources. Whether you need to brighten a large area with the floodlight, focus on a distant object with the spotlight, or preserve your night vision with the red light, the Oclip Pro covers it all.
Waterproof Rating: Durability in Harsh Environments
Both models are designed to handle outdoor conditions, but the Oclip Pro is more resilient in wet environments.
Oclip Pro:
• IPX6 rating: Protected against high-pressure water jets from any angle, which means it can withstand heavy rain and direct water exposure.
Oclip:
• IPX5 rating: Protected against water splashes, making it suitable for light rain or accidental splashes but not heavy downpours.
If you plan on using the light in more extreme weather conditions or near water sources, the Oclip Pro offers more protection, giving it a clear edge for those who need more rugged durability.
Battery and Charging: Efficiency and Speed
Oclip Pro:
• Battery Capacity: 580mAh
• Charging Time: 1 hour 30 minutes for a full charge.
• Charging Speed: More substantial battery size with quicker charging ensures the Oclip Pro is ready for extended use.
Oclip:
• Battery Capacity: 280mAh
• Charging Speed: Though it has a smaller battery, the Oclip charges in the same amount of time, but its reduced battery capacity limits the total runtime.
Despite having a smaller battery, the Oclip still offers efficient charging times. However, with the Oclip Pro’s larger battery, you can expect it to last longer between charges, especially under higher brightness settings.
Brightness Comparison: Shedding Light on the Performance
• Oclip Pro offers 500 lumens in the floodlight mode, which is significantly brighter than the Oclip’s 300 lumens in the same mode. This makes the Oclip Pro better for those who need a higher output of light for wider coverage.
• The Oclip Pro also provides an additional 380 lumens in spotlight mode, which is useful for focusing light on a specific target, as compared to the Oclip’s single floodlight.
Which Oclip is Right for You?
Choosing between the Oclip and Oclip Pro ultimately depends on your needs:
Oclip Pro:
• Best for users needing maximum versatility and power: If you need a versatile light with multiple lighting modes for different tasks, the Oclip Pro is the superior choice. It’s perfect for users who require more power for outdoor activities, professional tasks, or general use.
• Enhanced lighting options: With three light types, Oclip Pro offers flexibility for different environments and lighting requirements.
• Better waterproofing: The IPX6 rating ensures it can handle harsher conditions.
• More robust battery: Provides a longer runtime between charges, ideal for extended use.
Oclip:
• Best for users looking for simplicity and portability: If you prioritize a compact design and only need basic illumination, the Oclip is ideal. It’s light, small, and effective for everyday use.
• Lightweight and easy to carry: Weighing just 30g, it’s easy to clip onto clothes, bags, or hats without feeling heavy or cumbersome.
• Basic functionality: It offers two useful light modes for users who don’t need the additional options that the Oclip Pro offers.
Both the Oclip Pro and Oclip are fantastic, versatile clip-on lights, but the Oclip Pro offers more power, flexibility, and durability. The Oclip, while offering a more compact and lighter alternative, still provides all the essential lighting needs for general use. Whether you’re using it for hiking, professional work, or everyday tasks, both of these options deliver on our Olight's reputation for quality and reliability.
Ultimately, if you need pro-level power and versatility, go for the Oclip Pro. If you prefer simplicity and portability for light-duty tasks, the Oclip is an excellent choice.
