Olight Seeker 4 USB-C Rechargeable Bright LED Pocket Torch
Powerful Performance: It boasts a maximum brightness of 3,100 lumens and utilizes a metal reflector with a single XHP50.3 HI LED, enabling a throw beam that reaches up to 400 metres, surpassing the Seeker 3 by an additional 180 metres.
Universal Type-C Charging: Equipped with a Type-C charging port, the power supply becomes more accessible. Moreover, the light maintains its IPX8 waterproof rating even when the charging port is exposed.
Enhanced Battery Life: With a capacity of 5000mAh, it offers an impressive 15-day Moonlight runtime.
Metal Side Switch: The light is equipped with an upgraded stainless steel switch, enhancing its durability.
Tri-color Battery Level Indicator: Positioned at the centre of the switch is a tri-color battery level indicator that intuitively displays the remaining battery level.
