Olight Arkflex Rechargeable Powerful LED Torch With 0-90° Articulating Head
* The Thickness Data in usual manual which comes with the package is incorrect, please download the PDF version to check.
90-Degree Articulating Head: Allows you to flexibly adjust it to a specific angle for precise lighting.
Reliable Patent-Pending Non-wire Hinge: Validated through 10,000 swivel tests, the hinge ensures a continuous and consistent lighting experience.
Equal Top to Bottom: Thanks to its space-efficient hinge, the thin profile is perfect for pocket carry.
Five Brightness Levels + Strobe Mode: The various brightness levels make it suitable for a wide range of applications.
A Must-Have Versatile Light: The swivel head, along with the strong magnetic base and the two-way pocket clip, enables flexible and convenient hands-free use.
Easily Accessible and Durable Switch: Prominently positioned on the light body and with the other side ergonomically recessed, the switch can be easily located even in the dark.
